Hign-concerned Chemical: None
Communication method: zigbee
Compatibility: All Compatible
Brand Name: SMONSDLE
Origin: Mainland China
Tuya Zigbee Water Leak Detector Water Flood Sensor Smart Life App Alert Overflow Water Leakage Sensor for Kitchen/Bathroom
Note: First you need to connect the ZIGBEE 3.0 gateway in order to remote control from your mobile phone via 3G/4G/WiFi.
Description:
Low power consumption technology. The use of high-performance, low-power microprocessor, battery life of up to 1 year, to avoid frequent battery replacement (if the daily reminder of 20 times), the battery power is too low to send timely alarm notification
Specification:
Communication mode: zigbee 3.0
Supply voltage: DC3V (CR2032 battery, not included)
Material: Fireproof PC + fireproof ABS
System support: l0S8.0/Android4.0 and above
Application Name: Smart Life/TUYA
Operating frequency: 2.4GHz
Wireless technology: Zigbee 3.0
Wireless Distance: Indoor 30~50 metres
Operating temperature: -10℃~50
Packing list: 1 sensor, 1 manual (battery not included)
