Tuya Zigbee Smart Temperature and Humidity Sensor Detector Battery Powered Zigbee Hub App Monitoring Work with Alexa Google Home
Regular price $34.44
Regular price $0 $34.44 Sale price
Note:
1. Battery is not Included in packing.
2. ZigBee gateway is required, please purchase in addition.
Tuya Zigbee Smart Temperature Humidity Sensor Indoor Hygrometer APP Monitoring Works With Alexa Google Home Battery Powered
Model: ZSS-S01-TH
Product Name: Temperature & Humidity Sensor
Wireless Connection: Zigbee
Support Low Battery Alarm: Yes
Operating Temperature: -10°C ~ +50°C
Battery: CR2032 (replaceable,Battery is not Included. )
Temperature Measurement Range: -10°C ~ +60°C
Humidity Measurement Range: 0%-99%RH
Product Size: 40*26*13mm
Packing List:
Smart Temperature Humidity Sensor *1
Double-sided Sticker *1
User Manual *1
SMART TEMPERATURE HUMIDITY SENSOR
REAL-TIME & HISTORY RECORDS MONITORING
WHY WE NEED TEMP & HUMIDITY SENSOR?
According to research by the World Health Organization, the human body usually feels comfortable when the temperature is 22℃ to 26℃ and the humidity is about 40% to 60%. Too high or too low may easily cause heat stroke, eczema, rheumatism, etc. In severe cases, it may even lead to die. Therefore, maintaining appropriate temperature and humidity is very important for human health
IMPROVE INDOOR ENVIROMENT
VOICE MONITORING
WIDE APPLICATIONS
LONG-LASTING BATTERY LIFE
Equipped with CR2032 button battery lasting for one year, there's no worry about replacing battery frequently. The sensor will also push notification by MOES App when power is low.
50M/164FT COVERAGE OF COMMUNICATION
This sensor can cover a communication distance of 50m/164ft (without obstruction), allowing you to check the temperature and humidity at home at any time.
HIGH SENSITIVITY
The sensor has high sensitivity and can quickly detect changes in temperature and humidity. When the temperature changes by 0.3 degrees Celsius or the humidity changes by 5%, the sensor can immediately capture these changes and display them in the app in real time.
TAKE CARE YOUR LIVING SPACE
Instead of worrying about the weather every day, you need a smart temperature and humidity sensor to check the current environment condition.
USE IT AS NEEDED
With adhesive tape on the back, the smart temperature humidity sensor can be sticked to anywhere you need.
Dimension
