Note: Intelligent linkage to tuya smart devices for normal use only, can not be used alone without tuya smart device; Need to be used together with ZigBee gateway.
Item: Tuya Zigbee smart knob scene switch
Wireless Protocol: Zigbee (need zigbee gateway)
Working Voltage: 3V
Standby Current: â¤8uA
Battery Type: CR2450(include battery)
App: Smart Life / Tuya Smart
Working Temperature: -10°C~55°C
Working Humidity: âĽ90%
ăTwo-in-one device for wireless sceneăIn the scene mode, the button respectively support single click, double click scene requirements. You don't need to click the scene mode on your phone, just click the ZigBee smart remote control to open the smart scene.
ăWireless control of ZigBee dimming lamp in remote modeăAdd an intelligent knob switch in tuya intelligent ZigBee gateway, and then add an intelligent ZigBee light bulb under the remote dimming interface in the App, so you can remotely control your lamp wirelessly. (Note: Only ZigBee lamp can be added for control)
ăFour operations under remote mode to meet different demandsăSingle press to ON/OFF the bulb,rotate to normal dimmer,press and rotate to set the color temperature,and long press more than 3 seconds to set color,which clarifies the real-sense of value for money with this mini excellent device.
ăCreate multiple intelligent scenes for ewelink smart devices in App under scenario modeăTo create any smart automation as you want on your smart phone app to start your another intelligent lifestyle, when you are tired from one-day work,such as home mode, waterproof level up to IP55 for wider applications.
