Tuya Zigbee Self Powered Diy Whole House Smart Switch No Battery Waterproof Wireless Remote Control Kinetic Switches Set
Regular price $43.13
Regular price $0 $43.13 Sale price
Important Note: the switch panel only has RF433 function and does not have Zigbee function. It needs to be paired with a Zigbee receiver to use. Do not buy the switch panel alone, as it will not work!
Product Description:
Smart life APP and mobile phone pairing method, quickly press the learning button 5 times to enter the pairing mode, thank you!
Product size:
EU:86*86 mm, US:120*70 mm
Please purchase correctly according to the size of the switch panel at home, thank you!
This product is a WiFi+RF433 self-powered wireless light switch. You can control the lamps with the RF433 switch panel, or connect the phone via WiFi for Smart control. Thank you!
Wiring method:
1,wireless light switch receiver needs to be connected to a live wire and a neutral wire.
The (L in) marked on the receiver is connected to the power live wire (incoming live wire), and the (N in) is connected to the power neutral wire (incoming neutral wire).
The (L out) connects the live wire of the device that needs to be controlled (outgoing live wire), and (N out) connects the neutral wire of the device that needs to be controlled (outgoing neutral wire).
2,If you want the original wall switch to control the lamps at the same time, you need to connect S1 and S2 to the live wire and neutral wire of the original wall switch (the wiring of S1 and S2 does not distinguish between live wire and neutral wire).
In this way, the original wall switch can also be controlled. If S1 and S2 are not connected to the original wall switch, then the original wall switch is equivalent to the main switch of this line. It must be powered on, and the installed self-powered wireless switch can control the opening and closing of the lamps. Thank you!
The self-powered wireless light switch converts the kinetic energy of pressing into electrical energy, so there is no need for batteries, the switch panel does not need wiring, and it is energy-saving and environmentally friendly. Enjoy the convenient life brought to us by high technology!
Expand Your Lighting System Freely & Wireless Multi-way Switch You can use it as 2-way or multi-way switch to control the light from 2 or more locations. One receiver can hold up to 5 control switch panels. The switch can be placed or mounted anywhere. Make your life convenient, safer, and energy efficient.
Advantages and characteristics:
1. Supports many-to-one and one-to-many: multiple switch panels can control one receiver, or one switch panel can control multiple receivers!
2.This transmitter panel does not need batteries and wiring. It is plug and play, convenient andpractical, and easy to install .
3. Function: learning code.
4.100 meters remote control distance (open space), indoordistance is about 50 meters (no partition) (this data is the obstacle free test distance of the experimental open space, theactual distance will vary depending on the use environment and the obstacles, please take the actual distance as the standard) .
5,Widely used: This product can be used in esidence, hotel, villa, hospital construction sites, gardens, homes, farms, factories, offices, laboratories, supermarkets. Any device can be remotely controlled through a remote control, such as light,rolling shutters, fences, fans, desk lamps.
Specifications: Self-powered Wireless Light Switches
1. Type of work:ON /OFF
2. Power mode: Kinetic energy self-generation
3. Working frequency:RF433MHZ
4.Switching times:More than 800000 times
5.Product size:EU:86*86*mm, US:120*70*mm
6.Launch distance:330ft (outdoor), 100ft(indoor)
Receiver:
1. Working voltage:AC100V-240V 50/60Hz
2. Rated Current:AC 10A
3.Standby power:<0.15W
4.Working frequency: RF433MHZ
5. Storage switch quantity:Can store 5 wireless switch control(can be made)
Package: 1 x Wireless Switches 1 x Receiver 1 x English Instructions 3 x Adhesive Rubbers
Note:
1. Cut off all power before installing the receiver.
2. Cannot be installed inside a metal box as metal will shield signals and cannot be used!
