Tuya Zigbee Mini Temperature Humidity Sensor Smart Home Remote Monitor Works with Gateway Alexa Google Home Voice App Control
Regular price $23.18
Regular price $0 $23.18 Sale price
Tips for purchase: This product is Zigbee version,. Users must have/already bought a tuya zigbee hub to operate. If without a zigbee hub, then such model will not work.
• ZigBee Mini Temperature Humidity Sensor :The Tuya ZigBee mini temperature humidity sensor is designed to provide accurate readings of temperature and humidity levels in your home.
• Voice App Control :With the ability to control the sensor through voice commands, you can easily monitor the temperature and humidity levels in your home without having to touch the device.
• Gateway Alexa Google Home Compatibility :The Tuya ZigBee mini temperature humidity sensor is compatible with both Alexa and Google Home, allowing you to control the device hands-free using voice commands.
• CE Certification :The Tuya ZigBee mini temperature humidity sensor is certified by CE, ensuring that the device meets high safety and quality standards.
Tuya ZigBee mini temperature humidity sensor smart home Remote Monitor
works with Gateway Alexa Google Home Voice App Control
Description:
1.Tuya Smart ZigBee Temperature and Humidity Sensor Need to work with tuya Zigbee Gateway.
2.Real-time perception of temperature and humidity changes and real-time report to your smart phones with Smart Life Tuya App supported.View history record in App for smart controls for your house temperature and humidity.Monitor your house temperature and humidity no matter where you are.
3.Can be used with Alexa and Google home.
4.New ZigBee technology with low power consumption microprocessor for long standby.Designed with low voltage monitoring reminder function in App.
5.History Records Tracking.
Product name: Temperature and humidity sensor
Battery type:CR2450
Temperature detection range:‒10℃-50°C
Humidity detection range: 0%~95%RH
Temperature detection accuracy:±0.5℃
Humidity detection accuracy: ±3%
Wireless protocol:ZigBee
Product size:37*11.6mm
Package Included:
Sensor*1
User manual*1
Real-time display
Mastering changes in temperature and humidity tomake life more comfortableAlarm managementfor more peace of mindIntelligent Linkage
When the indoor temperature reaches 30℃turn on the air conditionerIntelligent Linkage
When the humidityis lower than 68 %turn on the humidifierVoice control:Free your hands with voice control°F &°C For Option
Completely solve the difference betweendifferent countries and unitsWide Usage:
