Tuya Zigbee Leak Sensor Water Leakage Detector Leakage Sensor Water Sensor Prevent Water Leakage for Smart Home Smartlife
Regular price $29.49
Regular price $0 $29.49 Sale price
Product Features:
1. Water poof, water leak detection
The sensor can detect whether there are water leakage at the installation location. If this is found, the information will be pushed to the phone immediately.
2. Easy to Install
The installation of the sensor is very simple, you can use adhesive taps to install at the location you need to install, please note that the installation location should be connected to the Zigbee Hub.
3. Use Zigbee, Tuya Zigbee hub is required
The sensor uses Zigbee to communicate with the server for data. So it won't be disturbed by other WiFi devices. Its communication link is more stable and faster.
4. Remote Monitoring
The alarm information and records of the sensors are all stored on the server. This design allows us to monitor whether there is water in the home or office from any place through the smartphone. And can also share the control information of the device to others.
5. Low battery consumption
The power consumption of the sensor in standby mode is very small, and one CR2032 battery can be used for one year. And when it detects that the battery is low, it will remind you to replace the battery through the alarm message.
NOTE: Do not support Zigbee2Mqtt
NOTE: Do not support Other Zigbee Hub.
Tuya Zigbee Hub Requested
This door sensor doesn't work alone. It need to work with Tuya ZigBee hub to function
Product Parameter:
Battery: CR2032(included)
Wireless Type: Zigbee(Tuya Zigbee Hub Only)
Working Temperature: 0℃~40℃ (32℉ ~104℉ )
Working Humidity: 20%~85% RH
Storage Humidity: 0%~90% RH
App Support: Smart Life
Material: ABS
Where can I use it?
You can install it in anywhere you worried about water leakage. For example: Kitchen, sink, bathroom, fish tank. Or you can use sensors to remind yourself that a container is full of water.
Working Principle
When the two feet of the detector was immersed by the water, the alert notifications will be pushed to your phone, be aware of water overflowing in time, reducing flooding risk.
APP Remote Control
Mobile APP control, connected to the network via Wi-Fi/3G/4G/5G, Remote control at any time. After the sensor detects the leak, it immediately pushes a message to your mobile APP
