Note: For HomeKit versions of finger robots, you need to add a ZigBee HomeKit gateway to the Home, and then go to the HomeKit in the Tuya APP to add a finger robot.
This device cannot be directly connected to the APP via Bluetooth or WiFi. It needs to work with Tuya Zigbee gateway/Multi -mode gateway.
Tool cannot be used alone. It need to be used with zigbee fingerbot plus!
Notice:
1.The zigbee fingerbot plus must be used with tuya zigbee gateway/Multi -mode gateway.
2.Work with Home Assistant Zigbee2MQTT and ZHA.(Z2M:1 gang switch. open/close switch) 3.Tool cannot be used alone. It need to be used with zigbee fingerbot plus.
Feature:
ăNew upgrade ZigBee versionă:Tuya HomeKit ZigBee Gateway/Hub is required
ăAPP remote control ă:The smart fingerbot plus can be controlled by mobile phone connect zigbee gateway.
ăVoice Control ă:The smart switch button pusher can be controlled through a voice device at home.
ăTimed startă:You can set the time in the APP and start the fingerbot button at a regular time.
ăConvenient installationă:Stick 3M glue on the bottom surface of the finger robot, paste it in the required position, open the mobile phone APP for configuration and use.
Specification:
Product Name: Zigbee Fingerbot Plus Dimensions: 34.5*34.5*34.5mm Weight: 38g Battery: 1 * CR2 not battery included
Torque: 2.0 kgf.cm Maximum arm movement: 12mm Wireless Protocol: Zigbee 3.0 Working Temperature: -10â-45â
