Tuya Zigbee Door Sensor Window Contact Sensor Open Closed Detector Smart Home Alarm Security Protection Work with Smart Life
Regular price $12.02
Regular price $0 $12.02 Sale price
1. This device only can work along with a Zigbee Geteway. You need to connect wifi with a Tuya zigbee gateway successfully before use such zigbee sensor.
2. The device is also compatible with eWeLink ZigBee Gateway Hub.
Ready-to-Go: The Tuya Smart Door Sensor is ready-to-go, meaning it can be easily installed without any complicated setup or configuration.
Alarm Alert: Whenever the sensor is triggered to open/close, it will send alarm to alert you that someone opens your door or window.
Enjoy Your Smart Life: When you leave home, it will push notification message to you when the door/window opens or closes, so you can discover the intruder in time. Furthermore, you could share the device to your family members and track the history of sensor activities.
Easy to Install: No complicated installation tools are required. The sensor can be installed with double-sided adhesive tape or screws(included) in just a few steps, and download an app "tuya" or "Smart Life" from GooglePlay or App Store to add the device to detect the status of your door/window.
Specifications
Wireless Type: Zigbee(need to use zigbee hub)
APP Name: Tuya Smart or Smart Life
Battery type: AAA1.5V*2 (not included)
Input Voltage: DC3V LR03
Quiescent Current: ≤10uA
Alarm Current: ≤160mA
Low Power Undervoltage: ≤2.7V
Magnetic Control Distance: ≥15mm
Working temperature: -10℃~50℃
Working Humidity: max 95%RH
Package Content
1* Zigbee Door Window Sensor
1* User Manual
1* Paper Clip
1* Double-sided Sticker
