Tuya Zigbee 3.0 PIR Motion Sensor Detector with Magnetic Base 360° Rotating Detect Human Body Movement Smart Home Security Alarm
Regular price $48.72
Regular price $0 $48.72 Sale price
Features:
【Zigbee Hub is required】 A Tuya Zigbee Gateway(Hub) is needed to work with the Zigbee motion sensor, and a variety of ZigBee smart products. The Zigbee Hub is the bridge and control center for smart homes and plays an irreplaceable role for all ZigBee products and realizes the whole intelligent linkage of your house. Simply add the zigbee sensor into the ZigBee hub after adding the hub to Smart Life/Tuya Smart App.
【Innovative Magnetic Base】 Innovative detachable magnetic base design, with 360° horizontal adjustment and 180° vertical adjustment, the sensor can be attached on the magnetic base with any angle you want.
【Real-time PIR Motion Detection】 When the PIR motion sensor detects human motion, it will send an alert push notification to the user's App on the smartphone and activate the local alarm on the Hub. Users can connect to a Zigbee alarm siren to make on-site alert.
【Scene Automation】 Users can set the PIR motion sensor with any other tuya Zigbee solution devices, such as smart bulb(switch), smart curtain motor(switch), air conditioner(smart remote control) to automatically turn on when the sensor is activated, to provide you a more comfortable life.
【Easy to Install】 Easy installation with 3M tape or just attached the base to the metal door or shelf.
【Detection Area】 Detecting angle: 90°, Detecting Range: 8 meter.
【Long Standby】 Ultra-low power consumption technology and low battery reminder. 1 year battery life.
Technical Parameters:
* Product Name: Zigbee Motion Sensor
* Communication Protocol: Zigbee 3.0
* Working Voltage: DC 3V
* Battery Type: CR123A(Optional), non-rechargeable
* Detecting Distance: 8m
* Detecting Angle: 90°
* Horizontal Adjustment: 360°
* Vertical Adjustment: 180°
* Recommended Installation Height: 2.2m
* Stand-by Current: ≤25uA
* Working Current: ≤30mA
* Low Battery Indication: 2.6V±0.2V
* Working Temperature: -10℃~+55℃
* Battery Life: 1 year(20 times a day)
* Dimension: 48*48*53 mm
Packing List:
1*Zigbee PIR Motion Sensor
1*Magnetic Base
1*User Manual
1*Double-sided Adhesive Tape
1*CR123A Battery(Optional)
- Innovative detachable magnetic base design, with 360 degree horizontal adjustment and 180 degree vertical adjustment, the sensor can be attached on the magnetic base with any angle you want.
- 8m detection range, 90° detection angle
App Push Notification
When the PIR sensor senses a person moving, it will push a warning message to your phone. When you are not at home, you can turn on your phone notifications to prevent thieves.
Link with Other Smart Devices Easily
Can be connected to Tuya smart bulb, smart light strip, smart switch, smart remote control, smart alarm siren, smart camera, etc...
Works with Smart Alarm Siren
The motion sensor can be connected to a zigbee alarm siren,when a person's moving is detected,the zigbee siren makes on-site alarm, scare off the intruder !
* Zigbee gateway and alarm siren are not included in the package.
Works with Tuya Smart Camera
The motion sensor can be connected to tuya smart camera. If someone breaks into your house, the smart camera takes photos and video automatically.
* Zigbee gateway and smart camera are not included in the package.
Works with Smart Bulb(Switch)
The motion sensor can be connected to tuya smart bulb and smart switch. When you come back home at night and enter living room, the light will be turned on automatically, no more worrying about the darkness!
* Zigbee gateway, smart bulb and smart switch are not included in the package.
Works with Smart Curtain(Switch)
The motion sensor can be connected to tuya smart curtain motor and smart curtain switch. When you come back home and enter bedroom, the curtains will be drawn automatically.
* Zigbee gateway, smart curtain motor and smart curtain switch are not included in the package.
Long Standby
- No battery replacement required for 1 year.
- Low battery reminder.
* Battery is optional.
Installed without tools
- This PIR human motion sensor comes with a double-sided adhesive tape, you can install your device without tools and stick it directly on doors, windows, drawers, cabinets, etc., ready to use!
- Recommended Installation Height: 2.2m
Multi-scenario Application
Can be used for home, warehouse, shop, apartment, etc...
Add Device in App
1. Make sure that you have already added zigbee gateway(hub) to Tuya Smart or Smart Life app,
2. Enter the zigbee gateway control page, tap "Add Subdevice",
3. Make the zigbee motion sensor enter the paring mode(indicator light blinks), then add it to zigbee gateway.
Sharing
Share control of this device with your family or friends through the App to enhance your relationship.
Product Size
Item Dimensions: 4.8*4.8*5.3cm
Package
Box Dimensions: 5x6x5cm
