Tuya Wifi/Zigbee Water Leakage Alarm Independent WIFI Water Leak Sensor Detector Flood Alert Overflow Security Alarm System Tuya
Regular price $24.49
Regular price $0.00 $24.49 Sale price
Product Parameter:
Title: Tuya Home Alarm Water Leakage Alarm Independent Wi-Fi Water Leak Sensor Detector Flood Alert Overflow Security Alarm System No Hub
Battery: AA*2(Batteries not include)
Wireless Type: 2.4GHz IEEE 802.11b/g/n
Working Temperature: 0℃~40℃ (32℉ ~104℉ )
Working Humidity: 20%~85% RH
Storage Humidity: 0%~90% RH
App: Tuya smart (Supports Android 4.4 and iOS 8.0 or newer)
Material: ABS
Product Features:
1. Water poof, water leak detection
The sensor can detect whether there are water leakage at the installation location. If this is found, the information will be pushed to the phone immediately.
2. Easy to Install
The installation of the sensor is very simple, you can use adhesive taps or screw (included) set to install at the location you need to install, please note that the installation location can be connected to the wifi router.。
3. Use Wi-Fi, No hub is required
The sensor uses Wifi to communicate with the server for data. As long as there is a wifi network connected to the Internet at home, it can meet the installation conditions.
4. Remote Monitoring
The alarm information and records of the sensors are all stored on the server. This design allows us to monitor whether there is water in the home or office from any place through the smartphone. And can also share the control information of the device to others.
5. Low battery consumption
The power consumption of the sensor in standby mode is very small, and two LR03 AAA batteries can be used for one year. And when it detects that the battery is low, it will remind you to replace the battery through the alarm message.
