Tuya Wifi/Zigbee Smart Temperature Humidity Sensor Outdoor IP65 Waterproof APP Remote Monitoring Works with Alexa Google Home
Regular price $27.68
Regular price $0 $27.68 Sale price
Note:
1. This product comes in both WiFi and Tuya Zigbee versions. The WiFi version can be directly connected to 2.4GHz WiFi for use, while the Tuya Zigbee version requires a Tuya Zigbee gateway to be used together. If you are not familiar with the Tuya Zigbee version, we recommend that you purchase the WiFi version.
2. This product can be used indoors and outdoors. If you are using it outdoors, please avoid direct sunlight, otherwise its temperature will rise due to exposure to sunlight, resulting in higher measurement results.
Through the "Smart Life" app, you can monitor the temperature and humidity in your home anytime, anywhere.
IP65Waterproof Rating
Support outdoor use, no need to worry about being affected by rain.
Intelligent Linkage Function
Support linkage with other Tuya devices. For example, in conjunction with the Tuya smart remote control, when the temperature exceeds 30 ℃, the air conditioning will be turned on.
Voice Control
Support Alexa, Google Home. With just one voice command, you can know the temperature and humidity of the room
Celsius (℃) or Fahrenheit (℉) Can Be Selected
You can freely switch between Celsius (℃) or Fahrenheit (℉) in the app
View Historical Data
You can view hourly and daily temperature changes in the app
Offline notification
When the device goes offline, your phone will receive a notification to let you know about it
Sharing function
You can share your device with family or friends in the app so that they can use this product like you do
Product Parameters
Product name: Tuya smart temperature and humidity sensor
APP:Smart Lifeor Tuya Samrt
Wireless Type: 2.4G WiFi/ Tuya Zigbee
Waterproof rating: IP65
Battery type:2*AAAbatteries(NOT INCLUDED)
Quiescent current:≤10uA
Alarm current:≤15mA
Detection temperature:-15℃~+60℃
Detection humidity:0-99%RH
