Tuya Smart Zigbee Temper & Humidity Sensor Smart Life App Home Automation Indoor Humiture Monitor Works with Alexa Google Home
Regular price $19.62
Regular price $0 $19.62 Sale price
Tuya Smart ZigBee Temperature and Humidity Sensor Smart Life APP Home Automation Indoor Humiture Monitor Detector Works with Alexa Google Assistant
Product Features:
1. High Temperature Humidity and Low Temperature Humidity Alarm:
Once the set value is exceeded, the alarm will be pushed automatically.
2. Real-time Monitoring:
Battery powered AAA 1.5V * 2 (excluding batteries), low power consumption.(The data update frequency is 1-120 minutes, and you can select the update frequency as needed. The smaller the value, the shorter the actual battery life.)
3. Temperature and Humidity Curve Chart:
Record the temperature and humidity changes on the APP and present them graphically for you. More intuitive to let you know recent data changes.
4. Scene Linkage:
This sensor can be used as a temperature and humidity data source for graffiti intelligence, smart life, Amazon Alexa, and Google Home. You can perform many automated processes based on data sources.
5. Third-party Voice Support:
This sensor supports Amazon Alexa and Google Home Assistant. You can hear the current temperature and humidity through voice.
Product Parameters:
Note: It can not be used alone and needs to be paired with a ZigBee3.0 gateway.
APP Home Platform:Smart Life APP / Tuya APP
Work With: Alexa and Google Assistant
Power Supply: AAA 1.5V * 2 (not including battery)
ZigBee Frequency: IEEE 802.15.4
Temperature measurement range: - 20 ℃~60 ℃
Temperature accuracy: ±1℃
Humidity measurement range: 10%~99% RH
Humidity accuracy: ± 5% RH
Size: 71 * 25 * 20mm
