Tuya Smart Wifi & Zigbee Temperature Humidity Sensor Indoor Hygrometer Thermometer Detector Alarm LCD Support Alexa Google Home
Regular price $38.20
Regular price $0 $38.20 Sale price
Tuya WiFi & Zigbee Temperature and Humidity Sensor Indoor Hygrometer Thermometer Detector Alarm LCD Screen Battery or USB Powered Support Alexa Google Home
Product Features:
High temperature/humidity and low temperature/humitity alarm】Once the temperature/humidity exceeds the set value, the device will emit a drip alarm sound on site and the phone will prompt an alarm
Temperature Unit Switch】You can switch the temperature unit between Fahrenheit and Celsius in the set.then press the reset button once, it will sync both on the screen and in the APP
Temp & humidity records】You can view the historic data of temp and humidity stored for 1 year, and export fo your Email address
Power supply mode】There are two power supply modes: USB and battery. When using battery power, the data update reporting time is 10-60 minutes, and when using USB power, the data update reporting time is 2 minutes.
Large LCD display screen】The sensor uses LCD as the display of temperature and humidity,
【Low Voltage Remind】
When the battery level is low, it will automatically remind you to change batteries, never worry about running out of battery.
【Third-party voice support】
This sensor supports Amazon Alexa and Google Home Assistant.
Specification:
USB Power Input: DC5V
Battery Input: DC3V AAA X2
Static Current: ≤90uA
Alarm Current: ≤40mA
WiFi: 2.4G, 802.11 b/g/n
Zigbee Standard: Zigbee 3.0
Detect Temperature: -10 °C ~ + 60 °C
Detect Humidty: 0-100%RH
Alarm Sound Volume: 55dB
Installation method: Wall mounted/ Horizontal placement
Working Temperature: -10℃~+60℃
Working Humidity: ≤90%RH
Temperature error: ± 0.5 °C
Humidity error: ± 5%
Alarm Mode: Mobile Phone App Notification Push(Smart Life/Tuya Smart)
Note: Zigbee Version Temperature and Humidity Sensor working needs to together with
TUYA Zigbee 3.0 Gateway Hub, Users need to purchase separately.
Package included:
1 x Temperature and Humidity Sensor(Not Included Battery)
1 x User Manual
