Tuya Smart Wifi/Zigbee Temperature and Humidity Sensor Indoor Hygrometer Thermometer with LCD Display Support Alexa Google Home
Regular price $26.83
Regular price $0 $26.83 Sale price
HIGHLIGHT
1. 【High temperature and low temperature alarm】Once the temperature exceeds the set value, the phone will prompt an alarm
2. 【High humidity and low humidity alarm】Once it exceeds the set humidity value, the phone will prompt an alarm
3. 【Real-time monitoring】Battery powered AAA1.5V*3 (battery not included), low power consumption, according to the system default settings, it can be used for about 1 year.
The data update frequency is 1-120 minutes, and the update frequency can be selected as needed. The smaller the value, the shorter the actual battery usage time
4. 【Temperature and humidity curve】Record the temperature and humidity changes on the APP and present them with graphics. More intuitive to let you know the recent data changes
5. 【Multiple installation methods】It can be placed directly on the table or hung on the wall. There is no data cable so it is more convenient and more beautiful
6. 【LCD screen display】The sensor uses LCD as the temperature and humidity display, and the time and date are displayed on the screen. The time and date are automatically calibrated.
7. 【Scene linkage】The sensor can be used as a temperature and humidity data source for Tuya Smart, Smart Life, Amazon Alexa, and Google Home. You can perform many automated processes based on the data source. Note that this function needs to be used with a universal infrared remote control, you can contact customer service to purchase
8.【 Temperature unit switch】The sensor is designed with the function of displaying the temperature in Celsius and Fahrenheit. You can select the unit to be displayed according to your needs. The switching speed is related to the set data update frequency. You can first select the update frequency for one minute, after one minute the temperature will switch to the new unit, and then switch the data update frequency to the time you need
9. 【Third-party voice support】The sensor supports Amazon Alexa and Google Home Assistant. You can check the current temperature and humidity by voice.
Specification
Power supply: AAA1.5V*3 (not including battery)
Zigbee support: tuya Zigbee3.0
Temperature measurement range: -10℃~55℃
Temperature accuracy: ±0.3
Humidity measurement range: 0%~99%RH
Humidity accuracy: ±3% RH
Package included:
1*Temperature humidity sensor
1*Manual
