Tuya Smart Home Zigbee Humidity Sensor - Wireless Temperature and Humidity Sensor with Backlit Clock Function
Regular price $26.82
Regular price $0 $26.82 Sale price
Doodle Smart Home ZigBee Humidity Sensor - Wireless Temperature and Humidity Sensor with Backlit Clock Function
Communication method: Zigbee (Requires to work in conjunction with a gateway)
Dimensions: 64X64X18mm
Operating temperature: -10 to +55℃, 0 to 100% RH
Power supply method: DC 5V
Characteristics:
1. Radio transmission circuit and encoding technology, solving the problem of signal interference and blockage
2. Multiple temperature modes adjustable, suitable for different scenarios
3. Wireless transmission of data signals, remote monitoring of mobile phones
4. Ultra-low power consumption, long battery life
5. Has low voltage monitoring alert function
6. Sends online reports to the host at regular intervals
7. Anti-tampering design for professional security field
8. Split design, high reliability
Single weight: 75g
Product packaging size: 71*71*27mm
Outer box size: 525*440*170mm
Box weight: 14kg
The quantity in the box is 210 PCS.
Packaging list: Temperature and humidity meter * 1 Instruction manual * 1
Note: There is an error of ±0.5 in the product data, which is within the normal range.
The reporting of temperature and humidity data is conditional:
The reporting rules state that if the temperature changes by ±0.5° or the humidity changes by ±2%, the data will be synchronized to the app platform.
