Tuya Smart Home Zigbee Door Sensor Alarm Window Door ON/OFF Detectors Security Protection Compatible with Alexa Google Assistant
Regular price $13.56
Regular price $0 $13.56 Sale price
Notice:
1、This device only can work along with a Zigbee Geteway. You need to connect wifi with a zigbee gateway successfully before use such zigbee T&H sensor.
2、Turn on the device and smart speaker (Amazon Alexa or Google Home speaker) , they will be connected automatically;
3、The device is also compatible with eWeLink ZigBee Gateway Hub. If TUYA Smart is not available for the device, please connect it with the eWeLink ZigBee Gateway Hub.
APP Name: Tuya Smart or Smart Life
Battery type: AAA1.5V*2 (Not include battery in shipment)
Input Voltage: DC3V LR03
Quiescent Current: ≤10uA
Alarm Current: ≤160mA
Low Power Undervoltage: ≤2.7V
Magnetic Control Distance: ≥15mm
Working temperature: -10℃~50℃
Working Humidity: max 95%RH
Wireless Type: Zigbee
ZigBee Gateway Hub:Required
Feature:
1.Ready-to-Go:The Tuya Smart Door Sensor is ready-to-go, meaning it can be easily installed without any complicated setup or configuration.
2.Control Channels: With 2 control channels, you can easily control the door sensor from your smartphone or tablet.
3. Alarm Alert:Wheneverthe sensor is triggered to open/close, it will send alarm to alert you that someone opens your door or window.
4. Alarm Recording:Support checking open / close records and battery level on the app. Never worry about missing any important moments or running out of battery.
5. Device Share:Select “Home Management” in the “Me” page to share your added sensors with family members. so that they can also monitor the status of doors/windows.
6. Low VoltageRemind:When battery level is low, it will automatically remind you to change batteries, never worry about running out of battery.
7.Works with amazon alexa and Google Assistant.
8.Enjoy Your Smart Life:When you leave home, it will push notification message to you when the door/window opens or closes, so you can discover the intruder in time. Furthermore, you could share the device to your family members and track the history of sensor activities.
9.Easy to Install:No complicated installation tools are required. The sensor can be installed with double-sided adhesive tape or screws(included) in just a few steps, and download an app "tuya" or "Smart Life" from GooglePlay or App Store to add the device to detect the status of your door/window.
package List
1xDoor Sensor (Not include battery)
1xUser Manual
1xDouble-sided tape
