- Brand Name: NoEnName_Null
- Origin: Mainland China
- Theory: Multifunctional Thermometer
- Hign-concerned Chemical: None
- Max Measuring Temperature: 70°C- 99°C
- Display Type: DIGITAL
- Certification: CE, FCC
- Style: Embedded
- Usage: Household
- Display Size: 1.9 Inches & Under
- Is Smart Device: YES
- Product Name: Wifi Bluetooth Dual Mode BBQ Thermometer
- Connection Method: WiFi5G/2.4G + Bluetooth 5.4
- Bluetooth Distance: About 328 feet/100 meters
- WiFi Distance: Unlimited control range(328 ft /100 m to the router)
- Food Measurement Range: -10℃~100℃/ 14℉~212℉
- Oven Measurement Range: 0℃~300℃/ 32℉~572℉
- Probe Response Time: within 1 sec
- Probe Battery Life: About 25 hours
- Probe Charging Time: About 25 minutes
- Base Battery: Built-in 2500 mAh lithium battery
- Base Charging Time: About 3 hours
- Offline Data Storage: 80 minutes
- Temperature Calibration: -7 to 7℃/-12 to 12℉
- Feature 1: Wifi BBQ Thermometer
- Feature 2: Bluetooth BBQ Thermometer
- Feature 3: Outdoor Meat Thermometer
Description
NOTICE:
1.This product is not suitable for use in microwave ovens or pressure cookers.
2.When inserting the probe into the food, ensure that it is inserted to a sufficient depth and beyond the safe cooking line.
3.During use, make sure that the distance between the probes and the base does not exceed 6 meters (19.68 feet). If there are obstacles in between, the distance should be shortened for a stable connection.
Main Features
- WiFi 5G+2.4G and Bluetooth 5.4, dual wireless connection modes
- Unlimited WiFi control range and 328 feet /100 meters Bluetooth connection distance
- Unique long and short probe combo for a variety of food materials
- Ultra fast probe response within 1 sec with a high accuracy of ±1℃/±1.8℉
- HD LCD with step-less dimming backlighting
- Saves 80 minutes of offline temperature data for data integrity
- Automatically switch to WiFi or Bluetooth mode for consistent monitoring
- Probes fully charged in 25 minutes last for 25 hours
- IP67 waterproof probes, easy to clean and can be used in dishwashers
- 28 types of meat menus with USDA recommended cooking temperatures
- Supports timers and multiple temperature alarms with settable alarm intervals
- Settable auto-sleep screen time for a more efficient power consumption
Specifications
- Probe Number: 2
- Probe Material: Food-grade stainless steel + Zirconia unglazed ceramic handle
- Screen Type: Backlit HD LCD
- Bluetooth Function: Bluetooth 5.4
- Bluetooth Distance: 328 feet / 100 meters
- WiFi Function: WiFi 5G + 2.4G
- WiFi Distance: Unlimited control range (328 ft /100 m to the router)
- Probe′s Waterproof Rating: IP67
- Probe′s Measurement Range: food temp -10-100℃/14-212℉; oven temp 0-300℃/32-572℉
- Probe′s Measurement Accuracy: ±1℃/±1.8℉
- Probe′s Response Time: within 1 sec
- Probe′s Battery Life: 25 hours
- Probe′s Charging Time: 25 minutes
- Base′s Battery: built-in 2500 mAh lithium battery
- Base′s Charging Time: 3 hours
Package Contents
Base*1
Long Probe*1
Short Probe*1
USB Charging Cable*1
User Manual*1
Quick Start Guide*1
There are no reviews yet.
