Shop Speco 8-Channel NVR Surveillance Kit With 6 IP Dome Cameras
The Speco 8-Channel NVR Surveillance Kit with 6 IP Dome Cameras and a 2TB hard drive is a comprehensive solution designed for robust security monitoring. This NVR system offers high-definition video recording and user-friendly features, making it ideal for both residential and commercial applications.
This surveillance kit includes an 8-channel NVR system capable of supporting up to eight cameras, providing flexibility for future expansion. The NVR comes with a pre-installed 2TB hard drive, ensuring ample storage for high-resolution footage. The system supports up to 5MP resolution for live view, recording, and playback, delivering clear and detailed images.
The six IP dome cameras feature a 2.8mm wide-angle lens and true day/night operation with an IR cut filter, ensuring optimal performance in various lighting conditions. With an IR range of up to 100 feet, these cameras provide reliable night vision capabilities. The cameras are IP66 compliant, making them weather-resistant and suitable for outdoor use.
- EZ Wizard: Simplifies network and system setup.
- EZ Record: Allows easy configuration of recording resolutions and types.
- EZ Copy: Enables quick copying of playback footage to a USB flash drive.
- EZ App Setup: Scan a QR code to view cameras on your mobile device via the app.
The Speco 8-Channel NVR provides a plug-and-play experience with PoE ports, eliminating the need for separate power supplies for each camera. The system supports H.265 and H.264 video compression formats, optimizing storage without compromising video quality. Remote monitoring is facilitated through PC, Mac, and mobile apps, allowing you to keep an eye on your property from anywhere.
Ideal for both indoor and outdoor surveillance, this NVR system is suitable for homes, offices, retail stores, and other commercial establishments. The weather-resistant IP dome cameras ensure durability in various environmental conditions, providing reliable security coverage.
In summary, the Speco 8-Channel NVR Surveillance Kit with 6 IP Dome Cameras and 2TB storage offers a comprehensive and user-friendly solution for your security needs, ensuring high-quality video capture and ease of access.
There are no reviews yet.
