Shop SONOFF SWV Zigbee Smart Water Valve
The SONOFF SWV Zigbee Smart Water Valve Automatic Irrigation system offers effortless control over your gardenâs watering schedule. Designed to simplify your irrigation routine, this smart water valve is easy to installâsimply connect it between your faucet and hose for a quick upgrade in just minutes. With Zigbee Smart Water Valve Automatic Irrigation, you can set precise watering schedules and control your irrigation system remotely using the eWeLink app.
This smart water valve supports single and cyclic irrigation, ensuring your plants, lawn, or vegetable patch receive the exact amount of water they need. Schedule automatic irrigation early in the morning, or start watering manually with just a tap on your smartphone. Whether youâre at home or away, the Smart Water Valve Automatic Irrigation system ensures your plants stay healthy without over-watering or wasting water.
Hign-concerned Chemical: None
Model Number: SWV
Brand Name: SONOFF
Origin: Mainland China
Certification: CE,FCC
Thread Standard: BSP, NH
Rating: 6V(4*1.5V AA)
Wireless connection: Zigbee 3.0
Working temperature: 5°C~60°C
Watering temperature: 5°C~40°C
Working humidity: 5%-95%RH, non-condensing
Waterproof: IP55
Dimension: 152x100x46mm
Color: Black
Casing materials: PC+ABS
Key features include IP55 waterproofing for outdoor durability, and battery life that lasts up to 20 months (with daily one-hour cycles). The valve also supports voice control via Alexa and Google Home, making it easy to integrate into your smart home ecosystem. Plus, you can track daily, weekly, or monthly water usage through the app, helping you manage your water bill efficiently.
Compatible with multiple Zigbee hubs and platforms, including SONOFF ZB Bridge Pro, Echo Plus, and open-source platforms via ZBDongle-P or ZBDongle-E, this device brings automation and ease to your irrigation setup. With real-time notifications for water shortages and multi-valve support, you can customize your watering routine for various areas of your garden, making your entire system smarter and more efficient.
Easy Installation, Smart Irrigation
Simply connect the Zigbee Smart Water Valve between the faucet and the hose to quickly upgrade your irrigation system in just three minutes, automatically watering your lawn, garden, vegetable patch, and more
Just a Touch to Irrigation
Busy with other tasks or traveling and unable to tend to your lawn in the morning? Open the eWeLink app, tap a button, and start todayâs irrigation immediately.
Effortless Automation Timed Irrigation
Donât want to wake up early to irrigate on weekends and just want to sleep in? Set a smart scene for the Zigbee Smart Water Valve to irrigate automatically in the early morning, making your life easier.
A Simple Voice to Control
Supports voice control through Alexa and Google Home. A simple voice command can close the water valve when you think itâs about to rain outside.
Working Together for Smart Irrigation
You can use multiple Zigbee Smart Water Valves to work together, setting different irrigation modes for various areas of your home, and creating a personalized smart irrigation system.
Track Water Data for 180 Days
Support checking up to 180 days of water usage and duration through the app. Understand daily, weekly, or monthly data to better control irrigation amounts and save more on water bills.
Expand Capabilities on Open-Source Platforms
The Zigbee Smart Water Valve supports Zigbee 3.0. Integrate it into open-source platforms via ZBDongle-P or ZBDongle-E to perform automatic irrigation functions.
