Somfy Ondeis WireFree RTS Rain & Sun Sensor
Regular price $299.95
Regular price $299.95 Sale price
Shop Somfy Ondeis Wireless RTS Rain And Sun Senso
The Somfy Ondeis WireFree RTS Rain & Sun Sensor is a state-of-the-art device designed to enhance your smart home automation by automatically managing your shading and lighting systems based on real-time weather conditions. This sensor is engineered to detect both sunlight intensity and rain, ensuring that your blinds, awnings, and other shading devices are perfectly adjusted throughout the day, regardless of the weather. With this sensor, your home stays comfortable, energy-efficient, and well-protected.
Features:
  • Dual Detection: The RTS Rain & Sun Sensor is equipped with advanced technology that accurately detects both sunlight levels and rain. This dual-functionality ensures that your shading devices respond appropriately to varying weather conditions.
  • Wireless Design: The Somfy RTS Sun Sensor operates wirelessly, allowing for easy installation and integration into your existing smart home system without the need for complicated wiring.
  • Automated Control: Once installed, this sensor automatically adjusts your blinds, awnings, or shades, protecting your home from excessive sunlight or rain damage. It communicates seamlessly with RTS-enabled devices, offering hands-free control.
  • Energy Efficiency: By automatically managing your shading systems, the sensor helps reduce energy consumption by minimizing the need for air conditioning or heating adjustments due to external weather conditions.
  • Weather-Resistant: Designed to withstand outdoor conditions, the RTS Rain Sensor is durable and reliable, making it suitable for various climates.
Benefits:
  • Comfort and Convenience: Enjoy a home environment that automatically adapts to changing weather, providing comfort without manual adjustments.
  • Energy Savings: Reduce energy bills by optimizing the natural lighting and shading in your home, thus decreasing reliance on artificial lighting and climate control.
  • Enhanced Protection: Safeguard your indoor and outdoor spaces from potential weather-related damage by ensuring your shading devices react promptly to rain and sun exposure.
  • Seamless Integration: The sensor easily integrates with other RTS-compatible devices, expanding your smart home capabilities without additional complexity.
Usage:
The Somfy Ondeis WireFree RTS Rain & Sun Sensor is ideal for residential and commercial properties where automated shading and lighting systems are used. It is particularly beneficial in homes with large windows, outdoor patios, or spaces where sunlight and rain can significantly impact comfort and energy use.
To use, simply install the sensor in an outdoor location where it can accurately measure sunlight and rain. Once connected to your RTS-enabled devices, the sensor will automatically control your shades, blinds, or awnings based on the detected weather conditions.
Product Specs:
Manufacturer Part #: 9019617
Power: Solar-Powered
Charging Time: Approx. 10 minutes in direct sunlight
Material: ABS
Radio Frequency: 433.42 MHz
Maximum Range: 65 feet under optimal conditions
Rain Sensitivity: The lowest setting (fully counterclockwise ) will react to very light rain 2-4 drops 1-2mm within 1-2 seconds or condensation or fog heavy enough to cause a drop to run down sensor. The highest setting (fully clockwise ) will react only to very heavy rain 1-2 inches per hour
Sun Sensitivity: Sun level threshold adjustable from 0.5 (CCW) to 50 klux (CW)
IP Rating: IP55
Temperature Range: Storage: -4° to 140° F (-20° to 60° C)
Operating: 32° to 140° F (0° to 60° C)
Dimensions: 4.53(L) x 2.60(W) x 1.97(D) inches (115 x 66 x 50 mm)
Shipping Weight: 1 pound
Approvals: FCC
Warranty: 5 Years
