Smart Zigbee Solar Soil Sensor Planting Temperature and Humidity Meter Waterproof Thermohygrometer Wireless Soil Moisture Meter
Regular price $85.37
Regular price $0 $85.37 Sale price
Smart Zigbee Solar Soil Sensor Planting Temperature and Humidity Meter IP66 Waterproof Wireless Soil Moisture Meter Garden Automation Irrigation Detector for Turf Gardening
Feature:
1. Smart Solar-Powered Sensor: The Planting Temperature and Humidity Meter features high-efficiency solar panels and rechargeable batteries for long-lasting power. Its 1.2V*3 NiMH battery ensures extended use, perfect for sustainable gardening.
2. Accurate Temperature and Humidity Testing: The Wireless Soil Tester utilizes Zigbee 3.0 technology for precise soil temperature and humidity sensing, ensuring optimal plant growth conditions and safeguarding your garden environment.
3. Convenient Remote Management: With the Thermohygrometer, use the app to monitor temperature and humidity data in real-time. Stay informed about your plants' status, view historical records, and switchs between Celsius and Fahrenheit for comprehensive insights.
4. Zigbee Wireless Long-Distance Transmission: The Wireless Soil Moisture Meter requires pairing with a gateway for operation, enabling seamless long-distance data transmission and integration into your smart home ecosystem.
5. Intelligent Linkage Control: The Garden Automation Irrigation Detector features smart scene linkage, automatically pairing with smart sprinklers to adjust watering based on soil moisture, creating an automated maintenance system for your garden.
Specification:
Origin: Mainland China
Communication method: zigbee
Color: Gray Purple
Battery: AA 1.2V * 3 NiMH batteries (rechargeable) included
Solar charging current: 35mA
Wireless protocol: Zigbee IEEE 802.15.4
Wireless distance: 50M
Waterproof grade: IP66
Temperature detection range: -10-60℃(14℉-140℉)
Humidity detection range: 0-100%RH (no condensation)
Conductivity maximum detection range: 20ms/cm
Temperature detection accuracy: 0.5℃ (adjustable)
Humidity detection accuracy: 5%RH (adjustable)
Conductivity detection accuracy: 3%FS 0.01ms/cm
Detection time span: 10min (adjustable)
Working temperature: -10-60℃ (14-140℉)
Working humidity: 0~100%RH (no condensation)
Dimensions: 146*78*78mm/5.75x3.07x3.07inch
Packaging size: 150*100*100mm
Gross weight: 254g
Note:
Due to different monitor settings and lighting conditions, the actual color of the item may vary slightly from the pictures. Thanks for your understanding!
Please allow a 1-2 cm difference in measurements due to manual measuring.
1 x Solar Soil Sensor
1 x Screw Pack
1 x Instruction Manual
