Smart Zigbee Scene Switch 4 Gang 12 Scene Switch Push Button Smart Life Controller Works with 2MQTT and Zigbee Gateway
Regular price $9.88
Regular price $0 $9.88 Sale price
Description
Product name : Smart Scene Switch
Battery Type : CR2032 3V * 1 (Do not included any button battery)
Operating temperature & humidity :-10°~55°C 95% RH
Communication: Zigbee 3.0
Product size : 86*86*13mm
App: smart life app
Use method : This device is zigbee device ,please use it with one zigbee gateway (no included)
Package lost:
Host machine x1
User manual x1
Double-sided tape x2
【NOTE】
1.Required Tuya ZigBee Hub and CR2032*1 battery. (not included)
2.Wireless scene switch don't support voice control
3.Control can only be achieved through other smart devices in your Smart Life APP.
1.【Wireless Remote Control】Smart automate the ZigBee wireless scene switch to any smart devices in Smart Life App to set various scenes for your smart life. Tap-to-run to get another easier control for all smart devices with one key on the switch.Each switch button can satisfy multiple needs, realizing different scenes.Imagine the smart linkage to create an infinite space with the wire scene switch.
2.【Push Button Design】This switch has 4 buttons, each of which can set 3 scene modes (click, double-click, and press). Three pairing modes for each button to achieve 12 scenes from one 4 gang scene switch,such as away mode,home mode,sleep mode,etc.To create any smart automation as you want on your smart phone app to start your another intelligent lifestyle.
3.【Use it anywhere you want 】Fix it anywhere you like with double-side tape;Low power consumption ;no wiring needed for simple use,easily establish multiple control to realize fast and easy upgrades.
4.【Smart Linkage 】You can use it to bind multiple Zigbee smart products in your house and control zigbee devices directly .
You can bind any smart product in each mode, and then achieve one click control over all bound smart products, achieving one click completion of scene modes without the need to open them one by one.
For example, you can set button 1 to leave home mode and bind a smart light bulb and smart curtain switch at home. Meanwhile, you can set the light bulb to off and the curtains to off in away mode. Of course, you can unleash your creativity to create more interesting and convenient ways for your smart home.
Notes:
1.Tuya ZigBee hub required,do not support other brands hub.
2.This product does not support voice control.
3.This product support Zigbee2mqtt,but not support ZHA control.
4.Intelligent linkage to tuya smart devices for normal use only,can not be used alone without tuya smart devices.
Feature:
• Tuya ZigBee Connectivity :Connects to your home network via ZigBee, allowing for easy and seamless integration with your existing smart home system.
• 12 Scene Switches :Control up to 12 different scenes in your home with ease, making it perfect for those who want to customize their smart home experience.
• Smart Life App Compatibility :Compatible with the Smart Life app, allowing you to control your switches from anywhere, at any time.
• 4 Gang Design :The 4 gang design allows for easy installation and integration with your existing electrical system.
Input Power:CR2032 3V *2(not included)
Communication:Zigbee 3.0
Working Temperature:-10℃~55℃
Working Humidity:<95%
Button Life:50000 times
Dimension:86*86*13mm
Tuya zigbee Hub:Required
APP:Tuya Smart/Smart Life
Package Included:
Switch*1
User Manual*1
Sticker*2
Regular price $9.88
