Smart Zigbee Pir Motion Sensor Radar Mmwave Temperature and Humidity Sensor Security Burglar Works with Home Assistant
Regular price $7.87
Regular price $0 $7.87 Sale price
Please note:
When purchasing the product, please read the product title clearly. Zigbee products are standard Zigbee 3.0 protocol products that can be connected to home assistant Zigbee 2mqtt, Yadex, Alexa and other standard Zigbee 3.0 protocol gateways and speakers. It is not recommended for users to connect to tuya Zigbee gateways.
Note: zigbee gateway required, not included battery!!!
【Zigbee Bridge/Zigbee Hub/Zigbee Gateway Required 】Sensors must be used in conjunction with Zigbee Bridge (not supported by other brands of gateways); Without this gateway, our product cannot function
【Advanced Motion Sensor】PIR detects human body or animals that are moving, about 120° detection angle,Up to 10m detection distance, can achieve real-time monitoring day or night.Sensitive sensing of human/pet movement
【Built-in Luminance Detection】This feature detects the brightness around your home and displays the lux value directly in the app, keeping you fully aware of the lighting conditions.
【Temperature and Humidity Type/No Temperature and Humidity Type 】 Optional, you can choose sensors with temperature and humidity detection or without temperature and humidity detection. We recommend that you choose a sensor with TEM and humidity detection, so that you can monitor the temperature or humidity in your home in real time
【Emergency Alert Push Function】If movement is detected, we’ll send alert notifications straight to your phone. This way, you can stay informed about what’s happening at home, even when you’re not there.
【History Records Tracking】Easily review past sensor activity by accessing detailed history
records whenever you need them.
【Intelligent Linkage for a Smarter Life】Connect this device to your Zigbee smart gateway to seamlessly integrate with other Zigbee-enabled smart products in your home, creating a more connected and convenient living experience.
【Strong Performance & Ultra-long Standby Time】Experience reliable performance with a long transmission distance, high sensitivity, and a strong network signal. The device runs on two
AAA LR03 batteries
(not included) and offers an impressive standby time of up to 18 months.
Regular price $7.87
