Smart Zigbee 3.0 RGBWW USB LED Light Strip Dimmable 5V RGBCCT TV Backlights Work with Hub Bridge Hub Echo Plus,App/Alexa Voice
Regular price $40.16
Regular price $0 $40.16 Sale price
【ZigBee Hub Required】Work with Standard ZigBee Gateway,the ZigBee LED Controller compatible with Hub Bridge,Gateway Lightify Hub,Tuya Smart Hub etc,If you don't have a gateway,the ZigBee LED strips will not work.
【Alexa Voice Control】No gateway required:Zigbee 3.0 Controller can directly work with:Echo Plus (2nd Gen),Echo (4th Gen),Echo Studio,Echo Show (2.Gen) and other smart speakers which built-in zigbee3.0 protocol.Use simple voice commands to adjust brightness,change colors or turn on/off LED lights.
【Smart APP Controlled】Can be integrated into your zigbee hub system,Easy App Control RGBW LED Strip Dimming,you can choose different scene modes or customize the light mode you want.Add fun to your TV LED Backlights Lighting,
【RGBCW WW LED Home Atmosphere light】You can get pure white light instead of mixing R.G.B white light,and offer 16 million color changes,1%-100% dimmable saturation control,Zigbee RGBCCT controller remembers the last color setting after switching off.
【Easy Installation】You can attach the TV LED backlight behind your TV easily,which has strong double-sided tape.3m TV LED backlight fits most size of(40-65 inch)TV,PC,closet,bookshelves,bed backlight and more;
Package include:
2m/3m strip light kit:
1 x ZigBeeRGBCCT controller with USB interface
1 x RGBCCT LED strip light ( 3m or 2m )
Only LED Controller:
1 x RGBCCT Zigbee 3.0 Controller
Controller type: ZigBee RGBCCT controller
Model NO:ZC05M-USB
Control options: Hub APP control/Voice Control
Color: RGB Cool White Warm white
Input voltage: DC5V/2A
Waterproof: Not waterproof
Connect with Gateway:
1. Connect the LED product to the power socket.
2. Start the device searching on the ZigBee Light Link Gateway which may take some time.(If the Gateway does not find the device, pls plug power off/on or make a reset.)
3. You can assign it to the different rooms/zones/groups after the Gateway found your device.
4. Now you can use the device.
Reset:
Method 1:
Long press the "Reset" button more than 3 seconds, The strip lights will blink rapidly 5 times and full bright It clear the network (reset) successfully.
Method 2:
1. Switch on your device.
2. Now switch off and on within 2 seconds.
3. Repeat off/on four times.
4. Reset is done when the device is switched on in the fifth time and the light stays on after blinking 5 times.
Notes: The Zigbee Strip Controller works with ZigBee Light Link Gateways / such as Lightify Hub, Homee, Smart Friends and Amazon Echo Plus and the 3rd generation Echo must be connected to the Zigbee Hub (Lightify Hub )
If the gateway cannot find the device and reset can't work, please try to restart the router and gateway.
