The Smart WiFi Temperature and Humidity Sensor is an advanced device designed for seamless indoor and outdoor environmental monitoring. It combines accuracy and convenience, allowing you to track temperature and humidity levels in real time via an easy-to-use app. With WiFi Temperature Sensor capabilities, this device connects effortlessly to your smartphone, delivering instant readings wherever you are. Built with an IP54 smart Waterproof Thermometer design, it’s suitable for various environments, from home interiors to outdoor setups. Whether for climate control or home automation, this Smart Humidity Meter helps ensure comfort and ideal conditions.
Monitor and control your environment effectively with the Smart WiFi Temperature and Humidity Sensor. Designed to withstand diverse conditions, this IP54 smart Waterproof Thermometer offers reliable temperature and humidity tracking for both indoor and outdoor use. By connecting to your WiFi, this sensor provides real-time data to your smartphone, letting you keep tabs on environmental changes from anywhere. With accurate readings, it’s ideal for homes, greenhouses, wine cellars, and more, ensuring comfort and protection of sensitive environments.
WiFi Temperature Sensor connectivity for real-time remote monitoring
IP54 waterproof design, ideal for outdoor conditions
Easy app-based setup and control
Compact and durable for versatile placements
Usage & Benefits
Suitable for monitoring temperature and humidity in various spaces
Protects valuable items from temperature-related damage
