The Door/Window Sensor consists of a magnet that attaches to a door or window and a 2.4GHz IEEE 802.15.4 standard wireless sensor that attaches to the adjacent door or window frame. Each Door/Window Sensor continually tests its battery and notifies the control panel when they need to be changed. The Door/Window Sensor will communicate intrusions to the home security system. When the magnet is moved away from the sensor, a signal is sent to the control panel that sets off an alarm if the security system is armed. Signals can also be used to activate a chime or convenience lighting based on system user settings
