Seco-Larm Enforcer Overhead Door Magnetic Contact, Open/Closed Loop
Regular price $20.95
Regular price $20.95 Sale price
The Seco-Larm Enforcer Overhead Door Magnetic Contact is a reliable and durable security solution for your overhead doors. Featuring both open and closed loop options, this magnetic contact can be used to monitor the status of your doors and provide an alert if they are opened unexpectedly. The contact is easy to install and can be used with a variety of security systems for added protection. With its rugged construction and reliable performance, the Seco-Larm Enforcer Overhead Door Magnetic Contact is an essential component for any secure building.
Product Specs:
Alarm Circuit Three-wire N.O./N.C. Contact for either closed or open circuit alarm systems
Reed Switch Gold under-plating with deactivated rhodium outer-plating
Switch Housing Weatherproof die-cast aluminum
Magnet Extra-strength Alnico 5
Wire 24 inches (61 cm), stainless-steel enclosure
Contact Lifetime 50 million cycles
Rating 0.02Amp./100VDC (max.), 0.2Amp./10VDC (max.), 3W (max.)
Temperature -15 to 160 ° F (-25 to 70 ° C)
Dimensions 4-3/8 x 1-3/4 x 7/16 inches (111 x 44 x 11 mm)
Gap 2-3/4 inches (70 mm)
Listings UL, RoHS
