Shop Starfish Wi-Fi Wall Switch – Modern Convenience in a Sleek White Finish
Introducing the Starfish Wi-Fi Wall Switch, a sleek and modern solution to elevate your home's lighting control. This white smart wall switch seamlessly integrates with your existing décor while offering advanced features for a connected lifestyle.
Smart Control: Manage your lighting remotely through the Starfish app or via voice commands with Siri, Alexa, Google Assistant, and SmartThings.
Versatile Compatibility: Supports up to 6A for incandescent, LED, CFL, or resistive loads, and up to 3.6A for motor loads. A neutral wire is required for installation.
User-Friendly Design: The switch measures 4.52" x 2.7" and includes a single-gang wall plate for easy installation.
The Starfish switch allows you to control your home's lighting from anywhere, providing convenience and flexibility. Whether you're at home or away, you can turn lights on or off, set schedules, and create scenes to match your mood or routine.
Enhanced Convenience: Operate your lights without leaving your seat or even while you're away from home.
Energy Efficiency: Schedule lights to turn off when not needed, reducing energy consumption.
Improved Security: Automate lighting to give the appearance of occupancy, deterring potential intruders.
Upgrade to the Starfish Wi-Fi Wall Switch and experience a new level of smart home living.
