Shop HomeKit DIY Smart Switch
The Refoss HomeKit DIY Smart Switch is the perfect solution for upgrading your home automation setup. This DIY Smart Switch allows you to transform your everyday appliances into smart devices with easy installation and control. Whether it's a smart lamp, fan, or space heater, this switch is designed for effortless integration into your existing home ecosystem. Compatible with Apple HomeKit, Alexa, Google Assistant, and SmartThings, this WiFi Smart Switch puts full control of your household devices right at your fingertips.
With support for HomeKit DIY Smart Switch functionality, you can use Siri voice commands for hands-free control, making it easier than ever to manage your devices. Its versatile design works with a wide range of devices, supporting input and output voltages from 90-250V, with a maximum load of 10A. Plus, you can control your appliances from anywhere using the Refoss app, and set schedules for automatic on/off operation, even when you're offline.
Key Features:
WiFi Smart Switches: Control your devices remotely from your smartphone, no hub required.
- Voice control support: Works with Siri, Amazon Alexa, and Google Assistant for hands-free operation.
HomeKit DIY Smart Switch: Specifically designed for Apple HomeKit users, offering seamless integration with your iOS devices.
Offline Control: When disconnected from the internet, the switch still works locally via the Refoss app.
Custom Schedules: Create automatic on/off routines with sunrise and sunset timing to optimize energy use.
Universal Compatibility: Suitable for a variety of household appliances (100-240V AC, max current 10A).
Easy Installation: DIY setup takes just 10 minutes, ideal for those who want to quickly transform their home devices into smart ones.
Benefits:
- Saves energy by creating customized schedules.
- Provides peace of mind by letting you check device status from anywhere.
- Improves convenience with voice control via multiple platforms.
- Enhances home automation with WiFi Smart Switches that don’t require a hub.
