Platinum Tools SealSmart PROCON Compression Tool
(5.00)5 Reviews
In Stock
$66.95
SKU: PL16213C
Shop Platinum Tools SealSmart PROCON Compression Tool
The Platinum Tools SealSmart PROCON Compression Tool is an essential device for professional cable installers, designed to deliver quick, precise, and reliable termination of RG6 and RG59 coaxial cables with F-type connectors. This high-performance PROCON Compression Tool is engineered for durability and ease of use, ensuring that it stands up to the rigorous demands of daily installation work.
Featuring a compact and robust design, the SealSmart Compression Tool is ideal for use in tight spaces where other tools might struggle to perform. Its patented rotating connector interface guarantees consistent compression results, ensuring a secure and lasting fit for every termination. This unique feature not only enhances the quality of your work but also increases efficiency by reducing the likelihood of faulty connections.
The Platinum Tools Compression Tool is built with an ergonomic handle, providing a comfortable grip that minimizes hand fatigue during extended use. This design is particularly beneficial for professionals who require a tool that they can rely on throughout long workdays. The tool’s straightforward operation makes it accessible to both seasoned installers and those newer to cable installation.
Key Features:
  • Patented Rotating Connector Interface: Ensures consistent compression results and a secure fit every time.
  • Compact and Durable Design: Perfect for use in confined spaces and built to withstand daily wear and tear.
  • Ergonomic Handle: Provides a comfortable grip, reducing hand fatigue during extended use.
  • Versatile Application: Designed for terminating RG6 and RG59 coaxial cables with F-type connectors.
Usage:
The PROCON Compression Tool is ideal for professional cable installers who require a reliable and efficient tool for coaxial cable termination. It’s perfect for both residential and commercial installations, ensuring high-quality connections in every job.
Benefits:
  • Reliable Performance: Consistent compression results with every use, reducing the risk of faulty connections.
  • Increased Efficiency: Streamlines the cable termination process, saving time and effort.
  • Durability: Built to last, even with frequent use in demanding environments.
Product Specs:
Dimensions 7 x 2.5 x 1 inches
Weight 15.2 ounces
Customers Reviews
(5)
  1. Aadarsh (verified owner)
    The product is firmly packed.
    1 product
  2. Lucas (verified owner)
    Very fast delivery.
    1 product
  3. Dominic (verified owner)
    Good quality.
    1 product
  4. Riley (verified owner)
    Very fast delivery.
    1 product
  5. Kevin (verified owner)
    Very fast delivery.
    1 product
Back to Top
chatsimple
