The Platinum Tools EZ-RJ45 Crimp Tool is a high-quality crimping tool designed for use with RJ45 connectors. This tool features a precision die head that ensures accurate and consistent crimps every time, and it is compatible with both stranded and solid wires. The ergonomic design of the tool makes it comfortable to use for extended periods, and the built-in wire cutter and stripper add to its versatility. With its rugged construction and reliable performance, the Platinum Tools EZ-RJ45 Crimp Tool is the perfect choice for professional installers and DIY enthusiasts alike.
Crimps and trims extended wire in EZ-RJ45 Connector in a single cycle |
For use with EZ-RJ45 Cat 5/5e and Cat 6 Connectors |
Will also work on most other RJ-11, RJ-12 and RJ-45 connectors (Except AMP) |
Patented |
Aiden (verified owner) –
Good quality.
Max (verified owner) –
Very fast delivery.
Bryan (verified owner) –
Good service.
Richard (verified owner) –
Good service.
Good quality.
