Philio 4-in-1 Slim Z-Wave Multisensor
The Philio 4-in-1 Slim Z-Wave Multisensor is a compact, Z-Wave Plus-enabled device combining four key sensors—motion, door/window contact, light, and temperature. It offers a comprehensive solution for security and environmental automation in smart homes. Key features include motion detection (PIR sensor) with a 10-meter range, a sensor to monitor doors or windows, brightness measurement up to 500 lux, and temperature tracking from −10°C to 70°C. With a long-lasting lithium battery, this device seamlessly integrates with major Z-Wave controllers.
The Philio 4-in-1 Slim Multisensor is a compact, Z-Wave Plus-enabled device combining four key sensors—motion, door/window contact, light, and temperature. It connects seamlessly to Z-Wave Plus hubs, enabling integration into smart home setups. This multisensor offers a comprehensive solution for security and environmental automation in smart homes. It works with EzloPlus, HomeAssistant, SmartThings, and other Z-Wave hubs.
- Remote Control Anywhere: Control your home's security and environment from any location using your smartphone or tablet, thanks to Z-Wave connectivity.
- Motion Detection (PIR Sensor): Detects movement within a 10-meter range, ideal for security and occupancy sensing.
- Door/Window Monitoring: Tracks the open/close status of doors or windows, enhancing home security.
- Light Sensor: Measures ambient light up to 500 lux for automated lighting adjustments.
- Temperature Sensor: Monitors temperature from −10°C to 70°C to keep environments comfortable and efficient.
- Tamper & Low-Battery Alerts: Notifies about tampering attempts and low battery levels.
- Simple Installation: Very easy to install.
- Z-Wave Connectivity: US 908.42 MHz; some models EU 868.4–869.85 MHz, JP 922.5–926.3 MHz, AU 921.42 MHz, IL 916.0 MHz.
- Wide Compatibility: Works with EzloPlus, HomeAssistant, SmartThings, Homey, Hubitat, Aeotec, and other Z-Wave hubs.
SKU:
PHL-PST02-A-US
UPC:
850010803104
Protocol:
Z-Wave (908.42MHz)
Operating Voltage:
3.0 V by CR123A
Standby Current (Sleep Mode):
8.8µA
MCU Wake Up Current:
25 mA
Low Battery Voltage:
2.6 V
Communication Distance:
Min. 40 m indoor, Min. 100 m outdoor
Battery:
CR123A 1700 mA
Battery Life:
Up to 2 years (up to 3.5 years with 1700 mAh CR123A)
Detector Dimension:
96(L) × 28(W) × 23(H) mm
Detector Weight:
40 g
