Optex Multi-Focus PIR Motion Detector
Regular price $91.95
Regular price $91.95 Sale price
The Optex Multi-Focus PIR Motion Detector is a high-quality motion sensor designed to detect motion with precision and accuracy. The device features multiple detection zones, allowing it to accurately sense movement across a wide area. With a range of up to 40 feet, the Optex Multi-Focus PIR Motion Detector is ideal for use in both residential and commercial settings, offering reliable and effective security for your property. The device is easy to install and use, and features a sleek and modern design that blends in seamlessly with any decor. Whether you're looking to improve the security of your home or business, the Optex Multi-Focus PIR Motion Detector is the perfect solution.
Detection Method Passive infrared
Coverage Wide angle: 85° wide 21m x 21m (70ft. x 70ft.)
Long range: 45m x 2.4m (150ft. x 8ft.)
Detection Zones Wide angle: 68 zones
Long range: 22 zones
Mounting Height 1.5m – 3.6m (5 – 12ft.)
Sensitivity 1.6° C at 0.6m/sec. (2.4m mounting height)
3° F at 2ft./sec. (8ft. mounting height)
Detectable Speed 0.3 – 1.5m/sec. (1 – 5ft./sec.)
Power Input 9.5 – 16V DC
Current Draw 8mA (normal) / 11mA (max.) at 12V DC
Alarm Period Approx. 2.5 sec.
Alarm Output N.C. 28V DC 0.2A max.
Tamper Switch N.C. Opens when cover is removed. 28V DC 0.1A max.
Pulse Count Approx. 20 sec. 2 or 4
Warm-up Period Approx. 60 sec.
LED Indicator Alarm condition
RF Interference No alarm 30V/m
Operating Temperature -20° C to 50° C (-4° F to 122° F)
Environmental Humidity 95% max.
