The On-Q/Legrand PoE Injector Mounting Plate is the perfect solution for mounting your Power over Ethernet (PoE) injectors. This plate provides a secure and convenient way to mount your PoE injectors directly onto a wall or other flat surface. The plate is designed to fit most standard PoE injectors and is made from high-quality, durable materials to ensure long-lasting performance. The compact design of this mounting plate makes it easy to install in any location, while its sleek and modern appearance blends seamlessly into any environment. Whether you’re setting up a new network or upgrading an existing one, the On-Q/Legrand PoE Injector Mounting Plate is an essential accessory that will help make your installation simple, secure, and hassle-free.
Product Specs:
Color | Black |
Finish | Corrosion resistant, powder coat |
Footprint | One enclosure module bay |
Typical Applications | Mounting up to 4 DA24XX products in On-Q style enclosure |
Type | Mounting plate for POE Injector |
Connection Method | 8 screws provided for mounting DA24XX products |
Humidity | Max. 93 percent non-condensing |
Material | 18AWG C.R.S. (Cold Rolled Steel) |
Mounting | On-Q Style Enclosure |
Shape | Rectangular |
Dimensions | 2.9(H) x 6.3(W) x 0.298(D) inches (7 x 16 x 0.76 cm) |
Weight | 0.25 pounds |
Riley (verified owner) –
Good service.
Liam (verified owner) –
Very well worth the money.
Leo (verified owner) –
The product is firmly packed.
Mateo (verified owner) –
Very fast delivery.
David (verified owner) –
