On-Q/Legrand 1-Port Digital Cable Amplifier with Coax Network Support
(5.00)5 Reviews
In Stock
$53.65
SKU: OQVM2201V1
Brands:
Boost your cable signal with the On-Q/Legrand 1-Port Digital Cable Amplifier with Coax Network Support. This compact and easy-to-install device enhances your cable TV signal, ensuring you get crystal-clear picture and sound quality.
Key Features:
  • Signal Enhancement: The 1-Port Digital Cable Amplifier significantly improves your cable TV signal, eliminating fuzziness and pixelation for a better viewing experience.
  • Coax Network Support: With built-in coax network support, this Digital Cable Amplifier allows you to share your cable connection with other devices in your home network seamlessly.
  • Sleek and Durable Design: The amplifier features a sleek and durable design that blends seamlessly with your home décor.
  • Easy Installation: Comes with all the necessary mounting hardware, making installation straightforward and hassle-free.
Benefits:
  • Enhanced Viewing Experience: Enjoy a clearer and more reliable cable TV signal with the Digital Cable Amplifier with Coax Network Support.
  • Network Sharing: The built-in coax network support allows you to distribute your cable signal to multiple devices, enhancing connectivity throughout your home.
  • Aesthetic Appeal: The sleek design of the 1-Port Digital Cable Amplifier ensures it integrates well with your existing setup.
  • Simple Setup: Installation is quick and easy with the included mounting hardware, so you can start enjoying improved signal quality right away.
Say goodbye to fuzzy and pixelated TV signals, and upgrade to the On-Q/Legrand 1-Port Digital Cable Amplifier with Coax Network Support today for a superior home entertainment experience.
Product Specs:
Cable Type Coaxial
Color Black
Connection Type ANSI/SCTE 01 Compliant Brass Sealed CamPort F-Connector
Type Signal Amplifier
Housing Material Nickel Plated
Surge Protected 6kV Combination Wave: IEEE C62.41-1991 Cat. B3 on all RF ports, including power adapter
Compatible Power Supplies 120V 60Hz Adapter, Part # 104157-01 (included)
Frequency 5 to 1002MHz
mA 200mA
Ohm Value 75 Ohm Nominal impedance
Operating Temperature -40 to 140 degrees F (-40 to 60 degrees C)
Power Requirements 12VDC, 200mA
Typical Insertion Loss Less than 1.2 dB
Typical Return Loss More than 20 dB
Volts 12VDC
Diameter 2.3(H) x 3.5(W) x 0.8(D) inches (5.8 x 8.9 x 2 cm)
Customers Reviews
(5)
  1. Camden (verified owner)
    Very well worth the money.
    1 product
  2. Matthew (verified owner)
    The product is firmly packed.
    1 product
  3. Mateo (verified owner)
    Good quality.
    1 product
  4. Anthony (verified owner)
    Good service.
    1 product
  5. Bryan (verified owner)
    Good quality.
    1 product
Back to Top
chatsimple
