Note:
*This is original Aqara motion sensor for Xiaomi smart home, works with Xiaomi APP Mi Home, Aqara Home etc..
*This item must match the zigbee gateway to use. ( Like Xiaomi gateway 2, gateway 3 / Aqara HUB etc..)
(Click the photo go to the link)
Main Features
1.Work with other aqara smart devices
2.Intelligent induction: when somebody goes through, the night light will turn on automatically
3.Sense the lightness and dark of your room
4.Notice function: sent alert to you through the APP
5.ZigBee wireless connection
6.Built-in 1pc CR2450 cell battery
7.Detection distance: 7m
8.Detection angle: 170 degree
9.Working temperature: -10 - 45 Deg.C
10.Working humidity: 0 - 95pct RH
*An Aqara Hub / gateway is required
Illumination detection
Provide more information to smart lighting
The Aqara human body sensor has its own illuminance sensor, which can judge the brightness of indoor light and provide more information for smart lighting. Such as: when the light is dark and someone is passing by, turn on the night light, etc.
Comes with base stand
Suitable for a variety of display methods
Through the self-contained bracket, the body sensor can be rotated 360 degrees to adjust the angle suitable for the home environment. It can be used by placing or pasting at will, supporting multiple installation methods such as horizontal placement, vertical placement and upside down
Use multiple human sensors
Every room in the home can be detected intelligently
Before going to bed, the air conditioner in the living room has been automatically turned off. When you wake up at night, a warm night light will illuminate the darkness for you. Now, you only need to place human sensors next to appliances, doors, and beds, and you can intelligently sense the movement of humans or animals at any time to link with other smart home devices, making life smart everywhere
Simple connection, only two steps
With the Mijia multi-function gateway and other devices with gateway function, you can easily connect multiple Agara human sensors according to the prompts, and enjoy a comfortable life.
1. Add Aqara sensor to Mijia APP;
2. Press and hold the reset button for 3 seconds until the blue light flashes 3 times and release it.
