Motion Sensor with PIR Security Burglar Alarm Sensor Battery Powered Home Security Protection Alarm System Compatible with Tuya Zigbee Features: 1. Advanced Motion Detection: Equipped with a high-grade PIR sensor, this motion sensor relay detects human or animal movements within a 120° angle and up to 5 meters away, offering round-the-clock real-time monitoring and highly sensitive to the presence of people and pets. 2. Instant Alert Notifications: Receive urgent alerts directly to your smartphone with our infrared detector's immediate notification feature, ensuring you're always aware of any activity in your home, even when you're away. 3. Activity Log Tracking: Keep a detailed history of human body movement detector activity at your fingertips, allowing you to track past movements and patterns for added security and peace of mind. 4. Long-Range & Battery Life: Our smart security alarm sensor boasts an extended transmission range, high sensitivity, and network signal strength, coupled with an impressive long battery life, powered by a single CR2450 battery (included), lasting approximately 18 months. 5. Lux/Non-Lux Options: Choose between the Lux model of this wireless motion detector, which detects light intensity and displays Lux values on the app, and the non-Lux version for straightforward motion detection without brightness measuring capabilities.
Specification: Origin: Mainland China Material: ABS Size: 27*33mm/1.05*1.29in Detection: 120°, Distance <5m Power Input: CR2450 Button Battery (1.5 Years, 10 Times A Day) Operating Temperature: -10°C~45*C
Note: Due to the different monitor and light effect, the actual color of the item might be slightly different from the color showed on the pictures. Thank you! Please allow 1-2cm measuring deviation due to manual measurement.
