The Meross New WiFi Smart Temperature Humidity Sensor Indoor Hygrometer is a cutting-edge solution designed to provide precise environmental monitoring for your home. With support for HomeKit and other major smart platforms like Alexa and Google Assistant, this sensor ensures real-time data tracking and automation. It helps maintain optimal indoor conditions by alerting you whenever temperature or humidity crosses set thresholds, making it ideal for various scenarios such as bedrooms, basements, or plant setups.
The WiFi Hygrometer Thermometer Sensor from Meross brings advanced environmental monitoring into the modern smart home. Built with a Swiss-made high-precision sensor, it captures temperature and humidity changes with exceptional accuracy. This Smart Temperature Humidity Sensor supports multiple platforms including HomeKit, Alexa, and SmartThings, allowing seamless integration with your home ecosystem.
Features:
Real-Time Monitoring: Track temperature and humidity levels remotely using the Meross app.
Automation: Trigger other devices like smart plugs or lights based on environmental conditions.
Long Battery Life: Utilizes ambient microlight collection for battery-free operation, ensuring years of hassle-free usage.
Two-Year Data Storage: Access historical data through the app and export it as needed.
Benefits:
Threshold Alerts: Set custom temperature or humidity limits and receive notifications when they are exceeded.
Flexible Placement: Compact and adaptable, it fits effortlessly in any corner of your home.
Enhanced Compatibility: Use the sensor with automation setups to switch appliances on or off based on temperature changes.
Meross Hub Required
Intelligently control the device via app after connecting it to meross hub
