Shop Meross 3 Way Smart Switch at Afforadable Price
The Meross 3 Way Smart Switch is the ultimate solution for upgrading your home’s lighting system. This Push Button Wall Switch allows you to control your lights from multiple locations while offering the convenience of smart technology. Simply replace one of your traditional 3-way switches with this WiFi Light Switch, and you’ll gain the ability to manage your lights remotely, set schedules, and automate your daily routines.
Compatible with Apple HomeKit, Alexa, Google Assistant, and SmartThings, this switch integrates seamlessly with your existing smart home ecosystem. You can turn lights on or off via voice commands or the Meross app from anywhere, at any time. The Meross 3 Way Smart Switch also features a status LED indicator, making it easy to find in low-light conditions.
Installation is straightforward and does not require a hub, although a neutral wire is necessary. The switch supports dimmable LED, CFL, and incandescent bulbs, making it versatile for various home lighting setups.
Features:
Replace one 3-way switch to smart-enable your lighting system.
Control lights remotely via the Meross app or voice assistants like Alexa and Siri.
Push Button Wall Switch design with status LED for easy locating.
Create schedules or set auto-off timers for hands-free automation.
Works with WiFi Light Switches for 2.4GHz networks without needing a hub.
Compatible with dimmable LED, CFL, and incandescent bulbs.
Easy setup with neutral wire required.
Model: MSS550X
Input: 120V~, 60Hz
Output: 120V~, 60Hz
Max Load: 200W (INC), 150W (CFL/LED)
Button: 1 x On/Off (5-second hold for reset)
LED: Status indicator
Dimensions: 1.7 x 1.5 x 4.1 in. (switch), 2.8 x 0.2 x 4.7 in. (wall plate)
WiFi: 2.4GHz only
Certifications: FCC, IC, ETL, UL
Compatibility: Apple HomeKit, Siri, Alexa, Google Assistant, SmartThings
Neutral Wire: Required
Control: App, voice control, schedules, no hub required
Elevate your home lighting with the Meross 3 Way Smart Switch, designed for convenience, smart control, and energy efficiency.
