Linknlink Emotion Pro Smart Home Sensor, Radar Presence Sensor, Motion2Mqtt Automation Module for Home Assistant
Regular price $99.66
Regular price $0 $99.66 Sale price
eMotion Pro Wi-Fi 24GHz mmWave Radar Presence Sensor
Precise Still Presence Detection | Smart Home Automations |Compatible with Alexa and Google Home | No Hub Required | Future Firmware Update for IR Control and Brightness Sensor
•【24GHz Precise Radar Presence Detection】The 3rd-Gen mmWave radar sensor detects presence with high precision, even when sitting or sleeping still. It offers superior accuracy compared to 2nd-Gen 5.8GHz radar or 1st-Gen PIR sensors.
•【Syncs with Home Assistant via Motion2MQTT】Motion2MQTT acts as a bridge, connecting the presence sensor to Home Assistant through the MQTT service. This integration allows Home Assistant to detect presence and trigger automated actions. For example, when someone walks by, Home Assistant can turn on a light, send a notification to your phone, or activate a security camera. The light will remain on as long as you are present, even without movement.
•【Wide & Barrier-Breaking Detection Signal】eMotion Pro can be installed in any direction or placed anywhere in the room, even inside a cupboard, while still accurately detecting presence. This provides exceptional installation flexibility, with a maximum detection range of 7 meters on the front side.
•【Easy & Fast Wi-Fi Connection】eMotion Pro connects directly to your home Wi-Fi network (2.4GHz), eliminating the need for an additional hub. This simplifies the setup process, provides faster response times, and reduces overall purchase costs.
•【Compatible with Alexa & Google】eMotion Pro is compatible with both Alexa and Google Home, enabling voice alerts and allowing you to set routines based on presence detection, further enhancing the automation and convenience of your home.
•【IR Control and Brightness Sensor】(To be enabled by future firmware update) Surprise! eMotion Pro also features long-range IR emitters for appliance control, with a range of up to 15 meters, and a built-in brightness sensor that detects ambient light levels. With just a single device, you can create complex automations, such as turning on lights when it is dark or turning off the AC when you are away for 30 minutes.
Stationary Presence Detection
The 3rd-Gen mmWave radar sensor detects presence with high precision, even when sitting or sleeping still, offering superior accuracy compared to 2nd-Gen 5.8GHz radar or 1st-Gen PIR sensors.
A future firmware update will activate the IR control and brightness sensor on eMotion Pro, significantly enhancing its capability for complex automations with presence detection-all in a single device.
Flexible Dual-Joints Foldable Stand
eMotion Pro includes a dual-joint foldable stand and adhesive stickers in the package, allowing for easy installation on a desktop or wall. The adjustable stand lets you fine-tune the angle for optimal detection performance.
Stay Informed with LinknLink App
No matter where you are, stay connected with real-time notification alerts for detected intrusions or prolonged inactivity. Easily view the event history, export data, and stay informed about your home directly from your phone.
Smart Home Automations Made Easy
eMotion integrates seamlessly with Alexa and Google Home, enabling you to create routines triggered by human movement, further enhancing your home automation and convenience.
Easy Syncing with Home Assistant via MQTT
No third-party integration needed! Simply utilize the standard MQTT service on Home Assistant and complete a quick setup in the app. eMotion will be automatically discovered in Home Assistant, with its status synced in real-time.
