Kwikset SmartCode 955 Reversible Electronic Lever, Satin Nickel
Regular price $167.95
Regular price $167.95 Sale price
Shop Kwikset Electronic Lever Lock SmartCode 955 In Satin Nickel
The Kwikset SmartCode 955 is a robust electronic lever lock designed for both residential and light commercial use. Its satin nickel finish adds a touch of elegance to any door while providing enhanced security and convenience.
The Kwikset SmartCode 955 is a commercial-grade Kwikset electronic lever lock that offers keyless entry through a durable touchpad, eliminating the need for traditional keys. It allows you to program up to 30 unique user codes, making it ideal for managing access for family members, employees, or guests. The lock is BHMA certified and has been tested to withstand 500,000 cycles, ensuring long-lasting performance.
  • Three Entry Modes: Switch between Auto Lock, Passage, and Disable Passage modes to suit various security needs.
  • SmartKey Security™: Protects against advanced break-in techniques and allows you to re-key the lock yourself in seconds.
  • Reversible Lever: Designed for easy installation on both left-hand and right-hand doors.
  • Extended Battery Life: Operates on a 9V battery with a lifespan of up to three years, depending on usage.
Ideal for exterior doors, offices, utility rooms, public restrooms, and vacation rental properties, the Kwikset SmartCode 955 provides flexible access control. Its Auto Lock mode ensures the door remains locked after each entry and exit, enhancing security. Passage mode keeps the door unlocked for free access during high-traffic periods, while Disable Passage mode requires a key or code for entry at all times.
  • Enhanced Security: With its commercial-grade certification and SmartKey Security, this Kwikset electronic lever lock offers superior protection against unauthorized access.
  • Convenience: Keyless entry and multiple user codes make it easy to manage access for different individuals without the hassle of physical keys.
  • Durability: Tested to high standards, the lock is built to withstand frequent use, making it suitable for both home and commercial environments.
Incorporating the Kwikset SmartCode 955 into your property enhances security and offers the convenience of keyless entry, making it a valuable addition to any door.
