Irismo 35 (Mini DC) RTS - Motorized Shade Controller
Regular price $550.95
Regular price $550.95 Sale price
The Irismo 35 (Mini DC) RTS is a cutting-edge motorized solution for your window coverings. This compact and powerful motor is perfect for small to medium-sized shades, blinds, and curtains. With its advanced RTS technology, you can easily control your window coverings with the touch of a button or through your home automation system.
The Irismo 35 (Mini DC) RTS is designed for quiet operation and smooth movement, ensuring that your window coverings will be effortlessly adjusted to your desired position. Its compact size makes it easy to install and integrate into your existing window treatments. Upgrade your home automation system with the Irismo 35 (Mini DC) RTS and experience the ultimate convenience and comfort in your daily life.
Manufacturer Part #: 1003004
Power Supply: 24V DC (included)
Amperage: 2A
Average Linear Speed: 4.9 in./s – 7.86 in./s (12.5 cm/s to 20 cm/s)
Power Consumption: < 3 W
Power Cable Type: 4 M (13.2 ft.)
Control Connector Type: RJ12
DCT Control Circuit Voltage: 5V DC
Motor Sound Level: < 44 dBA
Track Maximum Length: 32 ft. (9.7 m)
Maximum Number of Junctions: 2
Minimum Bending Radius: 11.8 in. (30 cm)
Minimum Curving Radius: 118 in. (300 cm)
Side Opening Max Weight: 77 lbs. (35 kg)
Center Opening Max Weight: 77 lbs. (35 kg)
Tandem Alternative: 154 lbs. (70 kg)
Certifications: CE
Warranty: 5 Years
