The HomeSeer Z-Wave Multi-Sensor is an advanced home automation device designed to enhance your smart home experience. This versatile sensor is capable of detecting motion, temperature, humidity, and light levels, providing comprehensive monitoring in a single, compact unit. With its Z-Wave multi sensor technology, it seamlessly communicates with other smart devices in your network, allowing you to create custom scenes and automate various functions within your home.
The HomeSeer multi sensor is perfect for improving home security, managing climate control, and optimizing energy efficiency. Whether you're automating lights based on room occupancy or adjusting your thermostat based on the current temperature and humidity, this smart multi sensor offers endless possibilities for smarter living. Its long battery life ensures reliable performance, while the easy installation process makes it a hassle-free addition to any room.
Usage:
Install the HomeSeer Z-Wave Multi-Sensor in any room of your home to monitor motion, temperature, humidity, and light levels. Connect it to your Z-Wave network to automate tasks such as turning on lights when motion is detected, adjusting the thermostat based on temperature changes, or triggering alarms for security purposes.
Benefits:
All-in-One Monitoring: Detects motion, temperature, humidity, and light levels with a single sensor.
Home Automation: Integrates with your Z-Wave network for customizable automation scenes.
Energy Efficiency: Helps optimize energy use by adjusting lights and climate controls based on real-time conditions.
Easy Installation: Simple setup process with long battery life for continuous monitoring.
Enhanced Security: Provides additional security by detecting movement and adjusting other connected devices.
Importance:
The HomeSeer Z-Wave Multi-Sensor plays a crucial role in making your home smarter and more efficient. By monitoring multiple environmental factors and interacting with other smart devices, this smart multi sensor enhances your home's security, comfort, and energy efficiency, making it an essential component of any home automation system.
Product Specs:
Manufacturer Part #:
HSM200
Z-Wave Chip:
500 Series (US)
Frequency:
908.42 MHz
Power:
120V, 60Hz
Indicator Colors:
Red, Green, Blue, Magenta, Cyan, Yellow, White
Requirements:
Z-Wave certified controller
Color LED feature requires HomeSeer HS3 system or other controller that supports the Z-Wave color command class
