• Maximum load for the Zigbee-controlled outlet: 600W incandescent; 1800W (15A) resistive or
1/2HP motor. Total load capacity for both outlets is 1800W (15A) resistive.
• Two Zigbee controlled AC outlets.
• Remote ON/OFF control via the Zigbee controller.
• Manual ON/OFF control with the front panel push button.
• Over-the-air updates — Once joined to your Zigbee network, the smart switch can transparently
receive updates through your Zigbee gateway .
• LED status indicator — Indicates smart switch scanning during network pairing process.
• Space-efficient design.
• Does not block the lower outlet when plugged in to the upper outlet of a duplex wall receptacle.
(This assumes that the duplex receptacle is mounted with the ground pin down.)
• Plugs and cords for connected devices route to the side, allowing close placement of furniture.
