SENSOR
Fortrezz Flood & Temperature Sensor (with probe) Z-Wave Plus
Regular price $25.90
Regular price $25.90 Sale price
This Fortrezz Flood Temperature Sensor alerts you when it gets wet. Just simply place it on the floor near water-using appliances and fixtures such as dishwashers, toilets, and washing machines. Water damage is caused by leaking pipes, corroded water heaters, leaky toilets, fixtures in bathrooms, laundry rooms with aging appliances, and more.
The sensor is a Z-WavePlus-enabled device. Pair to your SmartHome network and receive alerts to your phone when leaks are detected. Sensors work with our Water Shut-off Valve to prevent water damage from leaks by detecting the leak first, then turning off the water supply to the house, preventing any further leak.
Fortrezz Flood and Temperature Sensor
