For Tuya Zigbee Smart Water Leak Sensor Flood Leakage Sensor Overflow Level Detector Remote Monitor Home Assistant Zigbee2Mqtt
Regular price $22.17
Regular price $0 $22.17 Sale price
Zigbee 3.0 version need a zigbee hub to operate.
Zigbee 3.0 Water Leak Detector Water Flood Sensor App Alert Overflow Water Leakage Sensor for Kitchen/Bathroom
Note: First you need to connect the ZIGBEE 3.0 gateway in order to remote control from your mobile phone via 3G/4G/WiFi.
Description:
[Ultra-long battery life, low battery reminder] Low power consumption technology. The use of high-performance, low-power microprocessor, battery life of up to 1 year, to avoid frequent battery replacement (if the daily reminder of 20 times), the battery power is too low to send timely alarm notification
Specification:
Communication mode: zigbee 3.0
Supply voltage: DC3V (CR2032 battery, included)
Material: Fireproof PC + fireproof ABS
System support: lOS8.0/Android4.0 and above
Operating frequency: 2.4GHz
Wireless technology: Zigbee 3.0
Wireless Distance: Indoor 30~50 metres
Operating temperature: -10℃~50
Packing list: 1 sensor, 1 manual (no battery included)
When water overflows more than 0.5mm in the detected environment, the sensor
sends an alarm in real time and pushes a message to the mobile app.High Detection Sensitivity
High sensitivity, real-time insight into your home.
