Bring precision control, energy efficiency, and modern convenience to your home heating and cooling systems. With Z-Wave connectivity and a user-friendly interface, managing your home’s climate has never been easier. Upgrade to the Ezlo Thermostat and experience the perfect blend of technology and comfort.
Ezlo Z-Wave Thermostat Key Features
Z-Wave Enabled
Control your thermostat from anywhere using the Ezlo app.
Super Compatible
Works seamlessly with Ezlo smart home hub for an integrated smart home experience.
Touch Sensitive Controls
Navigate easily with a user-friendly, touch-sensitive interface.
Energy Efficient
Optimizes energy usage for cost savings.
Z-Wave Connectivity
Easily connect your Ezlo Thermostat to any compatible Z-Wave hub, allowing control and monitoring remotely from anywhere using your smartphone or tablet.
Works with Your HVAC System
Control systems ranging from heat pumps to AC units, with up to 3 stages of heating and 2 stages of cooling.
Seamless Integration with Ezlo Hub
Fully compatible with Ezlo smart home hub, enabling advanced automation and integration with other smart devices in your home.
Stylish Frameless Display
Navigate with ease using the sleek and responsive touch sensitive controls, designed for straightforward operation and quick adjustments.
Seamless Automation, Locally or in the Cloud:
Experience the power of total home control at your fingertips. The MiOS mobile app gives you the ability to easily add, view, and conveniently control your smart home devices, receive automated push notifications and much more.
• At-a-glance view and control of your custom smart dashboard
• Easily check your home’s temperature and adjust the setpoints from the app
• Create scheduled or triggered-based scenes
• Go advance with Meshbots and other third-party integrations
• Integrate your thermostat with other smart devices and control them locally or remotely via the cloud
Upgrade your home climate control with the Ezlo Z-Wave Thermostat and enjoy the ultimate in comfort, convenience, and energy efficiency. Whether you're at home or away, the power to manage your environment is at your fingertips.Get yours today and transform your home into a smart home.
Buy Now
