Instant Smart Control for Any Outlet
Make your appliances smarter and your energy bills smaller with the Ezlo Z-Wave Smart Plug.
- Plug-and-Play: Instantly upgrade lamps, heaters, and appliances—no tools or wiring required.
- Energy Monitoring: Track real-time power usage (watts & kWh) to spot inefficiencies and save money.
- Superior Range: Built on the Z-Wave 800 series for the fastest, most reliable connection possible.
Switch the AC output on or off via MiOS app or by using the manual Z-Button.
Supports power meter functionality to monitor and report wattage consumption and kWh energy usage.
Utilizes the Z-Wave 800 series for advanced, long-range connectivity.
- MiOS App: Control and monitor your switch remotely through the MiOS app, available for iOS and Android devices.
- Home Assistant Ready: Works with Home Assistant, enabling deep-dive automations.
- Energy Reporting: Supports power and energy meter reporting.
- Over-Current Protection: Supports over-current protection.
- US-Based Customer Care: Enjoy peace of mind with US-based, real-person customer support ready to assist you whenever you need help.
- LED Indicators: RGB LED shows Z-Wave network range and load power status.
- Advanced Automation: Seamlessly integrate with MiOS and other smart home hubs for complex automation routines.
- Home Assistant Ready: Works perfectly for simple use or deep-dive automations within Home Assistant and other smart home environments.
- Voice Activation: Compatible with Amazon Alexa and Google Assistant, allowing for hands-free control of associated devices.
AC 90-135V, 60Hz (Nominal input voltage: 120V)
10A MAX
≤1.5W
1800W
52mm (L) x 52mm (W) x 50.5mm (H)
AC 120V, 60Hz
Z-Wave Plus
Round up to 300 and 125 ft (depending on building materials)
908.40MHz, 908.42MHz, 916.00MHz
912.00 MHz (default), 920.00 MHz (backup)
Maximum Load Warning: This smart plug is designed for appliances up to 10A (1800W).
Do Not Overload: Ensure the appliance you plug in does not exceed this rating (e.g., avoid heavy-duty industrial equipment).
Over-Current Protection: The device includes built-in protection to cut power if the load becomes unsafe.
