Instant Smart Control for Any Outlet
Make your appliances smarter and your energy bills smaller with the Ezlo Z-Wave Smart Plug.
  • Plug-and-Play: Instantly upgrade lamps, heaters, and appliances—no tools or wiring required.
  • Energy Monitoring: Track real-time power usage (watts & kWh) to spot inefficiencies and save money.
  • Superior Range: Built on the Z-Wave 800 series for the fastest, most reliable connection possible.
Remote & Manual Control
Switch the AC output on or off via MiOS app or by using the manual Z-Button.
Power Metering
Supports power meter functionality to monitor and report wattage consumption and kWh energy usage.
Z-Wave 800 Series
Utilizes the Z-Wave 800 series for advanced, long-range connectivity.
App and Ecosystem Integration
  • MiOS App: Control and monitor your switch remotely through the MiOS app, available for iOS and Android devices.
  • Home Assistant Ready: Works with Home Assistant, enabling deep-dive automations.
  • Energy Reporting: Supports power and energy meter reporting.
  • Over-Current Protection: Supports over-current protection.
  • US-Based Customer Care: Enjoy peace of mind with US-based, real-person customer support ready to assist you whenever you need help.
  • LED Indicators: RGB LED shows Z-Wave network range and load power status.
  • Advanced Automation: Seamlessly integrate with MiOS and other smart home hubs for complex automation routines.
  • Home Assistant Ready: Works perfectly for simple use or deep-dive automations within Home Assistant and other smart home environments.
  • Voice Activation: Compatible with Amazon Alexa and Google Assistant, allowing for hands-free control of associated devices.
Power Supply:
AC 90-135V, 60Hz (Nominal input voltage: 120V)
Rated Load Current:
10A MAX
Power Consumption:
≤1.5W
Power Output (resistive load):
1800W
Dimensions:
52mm (L) x 52mm (W) x 50.5mm (H)
Operational Temperature:
AC 120V, 60Hz
Radio Protocol:
Z-Wave Plus
Range:
Round up to 300 and 125 ft (depending on building materials)
Z-Wave Radio Frequency (US):
908.40MHz, 908.42MHz, 916.00MHz
Z-Wave LR Radio Frequency:
912.00 MHz (default), 920.00 MHz (backup)
Ezlo
Ezlo Z-Wave Smart Plug 2 Pack
Regular price $49.30
Regular price $49.30 Sale price
Make Your Home Smarter & More Efficient Instantly upgrade your lamps and heaters with our latest smart plug! No tools required—just plug it in and go. With real-time energy tracking, you’ll see exactly where your money goes. Plus, with the Z-Wave 800 series inside, you get the fastest, most stable connection on the market today.
IMPORTANT SAFETY WARNING
Maximum Load Warning: This smart plug is designed for appliances up to 10A (1800W).
Do Not Overload: Ensure the appliance you plug in does not exceed this rating (e.g., avoid heavy-duty industrial equipment).
Over-Current Protection: The device includes built-in protection to cut power if the load becomes unsafe.
Frequently Asked Questions
Q: Do I need a hub to use this smart plug?
A: Yes. Unlike our Wi-Fi line, this is a Z-Wave 800 Series device. It requires a Z-Wave compatible hub (such as a Home Assistant or other Z-Wave gateways) to function and receive commands.
Q: Do I need an electrician to install this?
A: No. This device is 100% Plug-and-Play. Simply plug it into any standard wall outlet, and then plug your lamp or appliance into the smart plug. No tools or wiring are required.
Q: Does it track how much electricity I use?
A: Yes. The plug features robust Energy Monitoring. It tracks real-time wattage and accumulated kWh usage, allowing you to identify energy-hungry appliances and lower your utility bills.
Q: What is the wireless range?
A: This plug is built with the latest Z-Wave 800 Series technology, which supports Z-Wave Long Range. It offers superior connectivity, reaching more than 328 ft outdoors and significantly improving signal strength indoors compared to older Z-Wave versions.
Q: Does it work with Home Assistant?
A: Yes. The Ezlo Z-Wave Smart Plug is "Home Assistant Ready." It utilizes standard Z-Wave Plus (S2 Security) protocols, making it easy to include in Home Assistant or other open Z-Wave environments.
A: If you need assistance with pairing or configuration, our team is here to help. Please reach out to customer care at 866-966-2272 or email us at support@ezlo.com.
