Ewelink Zigbee Door Window Sensor Contact Sensor Security Burglar Alarm Magnetic Door Sensor Support Home Assistant Zigbee2Mqtt
Regular price $13.03
Regular price $0 $13.03 Sale price
Support Zigbee 2mqtt / Home Assistant】
Note :The zigbee sensor must be used with eWeLink zigbee gateway. Not supported Tuya/Smart Life.
Specification
Power supply: Battery CR2032 3V DC(included)
Communication: Zigbee 3.0
App: eWelink
Detection accuracy: ≥5mm
Size: Main body: 50*25*11mm;
Permanent magnet: 30*14*11mm
Operating temperature: -10 °C~45 °C
Life of battery: 1.5 years (General use, 10times per day)
Suggest you use the sensor with ewelink zigbee gateway ;
If you want to use with Alice /Yan dex /smarthings directly,please make sure your Alice /Yan dex /smarthings is built-in zigbee 3.0 hub;
[ Make your door/window smarter ] - when you leave home,it will push notification to you if the doors or windows are opened or invaded by an external boject,you will find anomalies in your home immediately
[ Battery powered ] - full of power long durable ,replace the battery is simple,service more intimate
[ PLUG & PLAY with Smart APP ] - Zigbee hub required
